doms HT, turnigy 9x apm 2.5 and ezuhf.
Started by Pr][nCe, August 06, 2014, 03:00:35 PM
Pr][nCe
Ok im stuck.
As stated above i have
fatshark doms, with the HT module. transmitter is the turnigy 9x with ezuhf module paired with long range diversity Rx, all running through APM 2.5.
9x is std firmware, and my apm 2.5 has a 6 position set for modes using, 3-position Fmode switch and the 2 position gear switch.
HT goes from doms to 9x via trainer port cable, oops there again does it it use to on my stock module "sheesh yes it does. although there is a 4 pin plug on the ezuhf module"?
9x is using channel 5 output to channel 8 input on apm 2.5 to select modes.
dom HT std config is channel 5 and 6 for P&T. how the hell do i get this to work, what channel outs should i use on the apm 2.5? or should i go to the Rx? this has cooked my noodle.
Darren.
Tricopter.  FPV.
2014 Skywalker 1800.  FPV.
Emax 250 Pro. FPV.
Bixler. Night flyer. LOS.
Versa Wing.
ClippedWing
As far as i know the HT just goes via your reciever directlty (EzUHF)
You set the HT up in the ImmersionRc tools (on your pc) have it always on
[img]http:/
Pr][nCe
ah ok.
my doms connect to 9x via trainer port "jackplug" just noticed there is a HT port on ezuhf Tx module but its a 4pin not a jackplug.
so i just go straight to Rx say channels 6 and 7 and then config in ImmersionRc tools.
job for l8rz.
BenLimeClouds.
Tricopter.  FPV.
Emax 250 Pro. FPV.
Versa Wing.
