FrSky TTFR4 SB no sbus out into Naze 32
Started by stevec, September 30, 2014, 10:22:46 AM
stevec
Hi peeps,
I have just got a mini quad and I am trying to set up the naze32.
I have done the feature PPM command to enable it in the board, but when I plug into the dedicated SBus port on the rx I get nothing.
I have checked the speed of the receiver and it is set to normal rather than high speed. if I connect to the 3 outputs and disable PPM I get a readout in baseflight.
I have also tried connecting a full non sbus receiver and that worked fine (again with feature -ppm) but I can't get this rx to work.
I know you used to have to use a jumper across 2 channels but this did nothing, and the new version doesn't mention doing that in the manual...
anyone encountered a similar issue?
Steve
stevec
just to update the thread, I asked on RC groups and the reply over there is the Naze expects PPM not SBUS,
so I have bought the wrong rx. I just thought they had changed the colour of the wrapper from white, but on further investigation that one was the ttfr4 b, so I'll probably stick this in my next helicopter and get the b variant for the quad..
/Steve
scalematt
I just found this out too for mt kk2 to x8r. No ppm!
