ImmersionRC launch the Uno and Duo V4
Started by Coyote, October 09, 2014, 01:36:17 PM
I have been waiting in anticipation for this to be finished. The new V4's are now 32 channel so can be used on all 5.8GHz Vtx's
A large price drop from £146 to only $91 so much cheaper than their predecessors.
I really hope there's more than one button for selecting channels!
friesianflyer
Quote from: Coyote on October 09, 2014, 01:36:17 PM
Where did you see them advertised? I have only found the uno.......?
mr_s81
Was thinking the same thing! Could only see the uno also.
Quote from: iPeel on October 09, 2014, 01:45:23 PM
Two buttons, one for band, the other for channel :)
Quote from: alreadytaken on October 09, 2014, 02:20:01 PM
Quote from: mr_s81 on October 09, 2014, 02:23:29 PM
If definitely says Duo5800
This if from Immersion`s own Facebook page :
https://www.facebook.com/ImmersionRC?fref=ts
Ohhh your way behind !! :)
Saying that I``m on the older V2 -85dbm so I was holding off on the V3 for the V4, my time has come muhahahah :)
Yes but it's still being finalized, due out soon, but don't hold your breath it will be very soon
I hope they drop the price for that as well. They as with the 5800's were a little steep in price. But happily they have dropped the 5800 prices
drambuidhe
Could I put a cp and a Patch( Immersion 13dbi longrange) on this vrx .
That way I won't lose signal when I return and go behind the patch unintentionally.
Cheers ;)
Yes you could, but you can also fly behind a patch as well, not very far but it's not like a wall so as soon as you go behind your pictures instantly lost or anything.
drambuidhe
Thanks, I may ask Santa for one of these then. :D
The video quality deteriorates badly when I forget to turn the patch to track the plane . If I use goggles and lose track of my position relative to the planes I can often lose video. At more than half a km the patch needs little guidance, its just close by I can get into trouble :o
Same with any directional antenna tbh, it's more pronounced the higher the gain too
Drone 5
Might be a bit of a daft question.
I was going to get the immersion Duo 5800 V3. Now out comes the V4. I will only be using the standard Fatshark frequencies so I will not need the other channels on the V4. Is there any other advantage to getting the V4 apart from the 32 channels?
M.
YouTube Channel     wad5uk
