Marcin mini QAV250 copy
Started by marcin, October 11, 2014, 03:26:01 PM
marcin
For now I manage to make that.
These are 6" carbon props with DYS engines ,which are really nice !
Still not sure to get acro naze32 or full naze32 ?
Lipo 3S nano tech 1.3Ah
rc frsky 2.4Ghz
for now all what's on pictures is 240gr   is that bad ,good or average ?
BTW - that yellow G10 wil be replaced with 2mm black G10 and bottom nylon standoffs with same as top ones but short 10mm.
Looking good mate :) Acro will do you, but I do miss a baro on mine to keep its height properly
marcin
finally i get acro ,think I will just keep this one to fly around LOS and learn myself ,keep practice etc:.
+ mystery 12amp esc's with DYS motors and these carbon 6" props. on 3s that quad might be fast .. ;D
marcin
finish and all up weight with
DYS motors
12amp mystery ESC's
6" carbon props
1.3Ah 3S nanotech
naze32
frsky 2.4 RC
FPV gear wdr600 + 600mW immersion + voltage reg.
479gr     :D
that thing just got initial hover in saloon and I must admit ,that thing will be FAST ! sound is awesome.
marcin
Pidge
Need to pull some weight out of my build...
200g - Tarot 250
5.7g - CC3D FCB
32g - 12A Mystery SimonK Flashed ESCs
101g - HD Sony FPV Camera
72g - DYS 2300KV Motors
9g - Spektrum AR610 Receiver
129g -  Turnigy Nano 11.1v 1500mAh
25g - TS58200 FPV Transmitter
573.7g - Total
Think I need the plastic cased FPV camera and use a smaller battery. What sort of flight time are you getting?
marcin
marcin
Pidge you use heavy hd camera and 1.5Ah lipo so weight is not that bad consider that.
I got 7min or bit more but not to much.
Pidge
Thanks for that, thought it would be the camera and battery.
