Cutting foam on laser cutter
Started by sammyben, November 12, 2014, 01:12:44 PM
sammyben
Hi,
Trying to cut foam on a laser cutter but it is burning around the edges. Anyone have any ideas to fix this.
Sam
A bit vague.
What type and thickness of foam?
ClippedWing
Faster feed rate would be my first guess, but burning foam with a laser your going to well burn it lol
[img]http:/
Quote from: ClippedWing on November 12, 2014, 02:04:08 PM
All sorts of foam can be successfully laser cut but obviously the settings for 3mm Depron and 50mm Zotefoam may differ a bit, hence the request for more info.
Hows about measuring how much has burnt away and adding it ont to your template or model or whatever
sammyben
Foam board is 3mm thick foam on a trotec laser
Sam
Quote from: sammyben on November 12, 2014, 06:09:28 PM
Sam
sammyben
#8
OK so it's white but still no mention of the type.
Your laser is suitable for Polyester (PES), Polyethylene (PE), Polyurethane (PUR) and Neopren foams. Contact Trotec for settings for these materials and help with whatever sort of foam it is you have. They too might ask what type of foam.
http://www.troteclaser.com/en-US-GB/Contact/Pages/Contact.aspx
http://www.troteclaser.com/en-US-GB/Support/Pages/Technical-Support.aspx
