hi still got a big prob with my osd and stuff need help
Started by MCPF1, June 17, 2011, 11:47:46 PM
MCPF1
hi guys i have had this problem for quite a while but have be working around it. the problem is with my osd, gps and elogger. when i plug everything in all i get on my goggles is a eagletree thing and when i move the 6ch a menu comes up but you can't do anyhing to it. thats just about all i get. i have tried all the stuff on psychosaffa's multiplex Royal Evo 9 Pro and works fine. tomorrow i will be trying his evo with my reciever to see if it is my transmitter or reciever. but he also said it might have something to do with the pcm or ppm but i don't know how to change that on my osd using the computer with the eagletree data recorder program but i don't even know how to use it.
electricmick
I have ET stuff and you either have two channels to control the menus or none. Just having one connected does not work. If you have this set-up correctly then I need a better description of you set-up and the issue to help you. Have you updated the software on both the logger and OSD? If not, do this but do not have the GPS connected as it will not work.
Miles
Wings: 2*X6, 2*X8, Z84
FW: Wot4, EZ*2
SZD Pirat 1:1
