help neded
Started by g.collins, July 24, 2011, 07:24:42 PM
Hi Guys
today I fought it would be a good Idea,to Chang my RC gear in the Easy Star for the Dragon link, I have tried to set the Fail safe, at 3/4 throttle and RTH, it is set but when I turn of the Transmitter it gos in to RTH, but only 1/2 throttle, it seems to not won't to chang, I tried the proses with the throttle of, just to see what would happen, it still remains at 1/2 throttle any suggestions.
regards G :)
Sounds like if its not going to zero throttle either your doing it wrong.
The rx has to be on, the transmitter set to failsafe positions and hold the DL button down till the LED goes off and back on again
Hi Coyote
The web sit stats to turn on the transmitter, set your controls to fail safe, then press the dragon button for a full 4 seconds, after 2 seconds the LED terns red, this stats that the transmitter is in fail safe, this is what I have been doing, but you say the LED has to go of and then on again,I will see if it gos of, thanks G
Your receiver is what stores the failsafe, not the tx. The tx cant tell it what to failsafe too if its lost the link, which is what failsafe is for.
