Vector in a wing
Started by MarkLincs, January 22, 2015, 01:44:20 PM
MarkLincs
All,
anyone know of any good Vector uTube videos or set up guides ?
Putting a Vector in a ZII and just like some guide to follow on set up and wiring...
- Still learning every day -
keukpa
I have a Vector in my Z2, setup is easy as a really easy thing...
MarkLincs
Quote from: keukpa on January 22, 2015, 02:36:57 PM
Yes you smart
Me IQ of glass of water
So a quick set up video / guide would be nice if there is one
Servo hook up
Mixing done by vector or my transmitter...
Extra channel hook up
Power to reciever hook up and servos etc
keukpa
Quote from: MarkLincs on January 22, 2015, 03:43:40 PM
Servo hook up
This is shown in the manual, just connect to CH1 and CH2 of the vector
Done by the vector, connect it to your PC first, and you will see the 'model' setup, the wizard is really easy to use.
for what? Currently the vector can't control any pan / tilt stuff
Yes, the vector can power the RX, just wire it in and good to go, however the servos will be best powered from a separate bec and not through the vector as on the Z2 they will pull a fair bit of current.
Keukpa
ThunderstruK
I'm with Keukpa here. It's very easy to set up. The manual is pretty straight forward abd the pc software is great too.
MarkLincs
Yea well
I really hate the way you have to power everything off a Bec...
But I'll conect to lappy soon enough
ThunderstruK
Once Yuri have done that you can enjoy how simple it is to set up.
MarkLincs
Yea
sounds like time to hook up to the laptop
then add a stupid BEC because the dam system won't power the servos so add a BEC add a 3s battery for receiver and servos oh Joy
keukpa
No need for a 3S battery to be added, use the BEC from the ESC to power the servos, and the Vector can power the RX no problems.
I'm not putting a separate 3S in mine.... no need!
Stellaship
Thought I'd ask here rather than starting a new Vector-wing thread.
Anyone give me a hand on the flight modes for fixed wing on a Vector? I'm not quite sure I understand the manual. I'm thinking I want to go for:
- Stabilization off: Just flying manually
- Gyro stabilize: Like above, but smoothes out lumps and bumps from turbulence?
- 2D Mode with hold: If I'm flying straight and level, it will keep flying straight and level without any input from me?
- Loiter: Got this
- RTH: Got this
(NB, spelling from the manual ;-) )
keukpa
Yes, you are correct in what you say, the 2DH mode is great.... flying at 400m due east... flick it into 2DH and it'll cary on at that till you change it with stick input :)
Stabalise, yes, this just removes the buffeting :)
I love the vector I does! :)
Keukpa
Vector is the best FC out there right now... the MFD Fanboys will be along shortly to disagree... but they're wrong so ignore them ;)
The only thing the Vector doesn't have going for it right now, is a plug n play Automatic Antenna Tracker.
keukpa
Quote from: BlueFlyer on November 28, 2015, 10:56:37 PM
What do you mean by plug'n'play?
the EagleEyes gives vector tracking and diversity.
"* Antenna Tracking - Is your video transmitter suffering from low range? When coupled with our Vector or OSD Pro OSDs, the EagleEyesTM is the heart of a full-featured pan/tilt antenna tracker. Powerful, easy to use PC software and on-screen menus are provided for adjusting the EagleEyesTM to work flawlessly with the tracker of your choice. An exclusive to Eagle Tree, multiple pan points can be calibrated, resulting in greater panning accuracy even if your pan servos are somewhat nonlinear. The built-in regulator drives even large pan/tilt servos, with no need for an external BEC. ReadyMadeRC.com and electronicarc.com produce low cost, high quality trackers built especially for EagleEyesTM."
http://www.eagletreesystems.com/index.php?route=product/product&product_id=84
Keukpa
With the Eagle eyes you need to hook it up to a diy or third party pan and tilt mechanism. I've done it and whilst it does work, it's a messy/cumbersome setup.
If Eagle tree brought out an all-in-one AAT like the MFD one, they'd make a killing
keukpa
Ah right, I get ya.
But it does have plug an play AAT, albeit lots of plugging ;)
Personally I prefer the Eagle eyes over a pre-built setup as it gives you many more options...but for out the box flying, the Skylark / MFD certainly has that one nailed!
Keukpa
