FY31AP
Started by n00b@FPV, September 11, 2011, 09:35:07 PM
hga77
Looking nice! How come you didn't go with ezosd (to get signal quality etc from ezuhf)?
Quote from: 6lennn on December 30, 2011, 07:12:17 PM
OMG
The rats nest below on bleedin works......
hga77
I have mixed ideas about both PPM and RSSI. What are they exactly?
6lennn
the feature i was most interested in was rth
Return to home/launch
RVOSD was out of stock with no gauratee of a restock date,
So the fy&hornet seemed the best available option for my wishes
tbh I'm chuffed with it, but I dont have knowledge nor anything else to compare it to
Miles
Quote from: hga77 on January 05, 2012, 01:26:51 PM
PPM is stands for Pulse Position Modulation. It contains the postions for all the servos for the channels your TX has.
RSSI is Receiver signal strength indicator
It is a voltage that can be made into a percentage on some OSDs to give you an idea of signal strenght
hope this helps a bit.
Wings: 2*X6, 2*X8, Z84
FW: Wot4, EZ*2
SZD Pirat 1:1
After selling my Tricopter, I've just ordered the FY31AP. It's destined for my FPV Raptor, but don't worry about all that rubbish from alishanmao about how the FY31AP doesn't like the FPV Raptor, that was all down to the stock electronics which I have replaced in full with known reliable equipment.
happy bunny right here :)
arrived yesterday (missus was out) picked up from distribution centre today. I can't get over how small this thing is!!!
one question... which is the right way up for the GPS sensor?
it seems a bit strange for them to put their gucci logo on the black part if it's just going to be mounted upside down?
should the logo be pointing to the sky or pointing to the ground?
6lennn
logo down, the side where you can see the edge of the circuit board should point to the sky
hth
Just ordered two of them today, look very capable so I gave in.
While looking up reviews a problem keeps cropping up, the FY31 was freezing on the ground and in the air. This has been fixed though, its the extension cable going to the Hornet OSD, only use the two wires cable, if you use the four wired one all hell breaks loose, ground station won't work, no responses to sticks etc  ;)
6lennn
ow-er, better check mine
runs off.......
phew, I though the 4 wire connector was just an extention for the gps
What I don't get is if the two wire cable is used to share the GPS, then how does the OSD get the data for the artificial horizon ?
6lennn
dunno but the setup that works is
gps plugged into the 31AP
there is a 4pin connector that has only 2 wires
ground to ground and pin3 to pin4
the connector with the white wire in pin4 plugs into the OSD, the side with the white wire in pin3 plugs into the 31AP
Instructions are not very clear on this so might save you some time, I wasted a good hour not realising this and kept swapping gps between osd and 31
Ah right cheers Glen :) I wonder what 4 pin 4 wire connector people keep plugging in on RCG then ?  :shrug:
I just use the black and White cable Ian, I used the four cabled wire for the gps extension, mine not locked up but not flown it yet though
Ok, after more digging around I've found out that you are highly recommended to flash the ap and osd with the new firmware as a bug was found for this freezing problem
http://www.feiyu-tech.com/download_list-en.php
That is what FY say you should do as soon as you open the box
An example of old firmware with bug :
Reboot of FY-31AP + Hornt OSD Combo...
6lennn
oh, thanks ian
lol, mine is v1.3
better get downloading
