New Micro MinimOSD
Started by HerkyBird, February 01, 2015, 12:57:37 AM
Ynot6
for a stand alone mAH meter, what current sensor would i need? and would it work "plug and play", or would i need to do some programming?
OMG, IT FLIES!
Quote from: iPeel on July 29, 2015, 08:45:59 AM
Excellent, that means your Skyfun will get a satellite lock in less than an hour!
Ha! Well at the moment I'm using your ezosd, but it's doing an odd thing with the speed, the distance from home is fine. You can see on my last vid.
Thanks shacks, I'll have a go once they arrive.
Shikra
Ched - Cleanflight is supported today. Need the latest dev for CF 1.9 release When ready drop me a mail.
ynot - almost all are supported. Suggest getting one of the APM ones.
This helps for configuring. There is a drop down list click on cell "c10"
https://docs.google.com/spreadsheets/d/1-NRiG__0Ym1Sw__0UR1on3XKo4--my3V4uDAUEjcMrk/edit#gid=0
You can also try the virtual one - its pretty good  for multicopters....
Ynot6
next dumb question, can the minim "talk to" the eagle eyes to use the tracking function?
OMG, IT FLIES!
Shikra
Unfortunately not possible.
Ynot6
OMG, IT FLIES!
Mine have just arrived. .. bloody tiny! Better not sneeze around them!
jimbo19
I can always solder it up for you :) - just ask Neil  :laugh:
Think I'll manage! Thanks!
Got it all flashed and configured from the gui, just need to find my gps and get that hooked up.
Can't get over how tiny this thing is!
Shikra
Yeah
they are tiny!
Not sure what version you put on but first 1.5 pre-release is out.
Only one issue raised for legacy support of Harikiri - so its looking like I will release it as full R1.5 end of the week.
https://github.com/ShikOfTheRa/scarab-osd/releases
and feature s/ changes to see if its worth updating are here:
https://github.com/ShikOfTheRa/scarab-osd/blob/master/OTHER/DOCUMENTATION/Features.md
Just put 1.4 on there, I'll do 1.5 later, thanks for the heads up.
jimbo19
Shikra can your code be used on the minimosd , but with an APM ?
rather than using minimosd extra which looks a bit chunky and clunky in comparison
Shikra
Currently supports:
MULTIWII
BASEFLIGHT
CLEANFLIGHT
HARIKIRI
NAZA
+STANDALONE GPS only
APM planned for later in year  - sorry!
OpenPilot - uncertain
gizmatron
Just ordered one of these.. anyone got a link to a suitably tiny current sensor? or I have one kicking about somewhere from my old feiyutech hornet. will that work? And I bought it preflashed to work as a standalone OSD. how do I calibrate whatever current sensor I buy.. the hornet one never read right when it was in use but the hornet had no way to calibrate or offset it..
Oops, after much setup and anticipation, I managed to fry mine today by cocking up my power connection from my Naze - reversed the gnd/5v and it popped.   So, er - don't do that :)
Just ordered another one, so it'll hopefully be here by the time MadDogs rolls around
