New Micro MinimOSD
Started by HerkyBird, February 01, 2015, 12:57:37 AM
It's like a sickness, if I'm not making a video for YouTube, then what's the point :)  Anyhoo, a few teething troubles for me, but this is bloody excellent
! No longer available
Badlands
Ive been using these OSD's for a while but with a different firmware.
This firmware is by Dennis Frie.
Very configurable.
http://www.rcgroups.com/forums/showthread.php?t=1776186
Its more of a stand-alone OSD which looks a lot like EZosd but for around £5 + a GPS unit it gives me speed & a home arrow.
mrwilljackson
I've been using Denis osd as well, it seems to work well :-)
Shikra
Probably a bit cheeky, but MWOSD has a number of predefined screen layouts. One of which is same as EZOSD!
Even better with ha vid CK!
Anyone got any ideas what might be wrong if I'm get no video at all being passed through the board?
This was my own stupid fault, just got some connections reversed.  Got it all hooked up and working now, however one small issue I have is that I can't seem to connect the Naze board to the Cleanflight configurator if it's also connected to the OSD, very strange.
Shikra
both can't use same serial port at same time. Either have to unplug, configure another serial port or use soft serial.
Basically CF settings and right pin connections!
Personally I just unplug....
Cool, ta.  I'll just unplug it then, I'll hardly ever be doing now that I can tweak PIDs through the OSD anyway.
marcin
Hey I just flash my minim micro OSD with MWOSD 1.4
I know it talks nicely with NAZE32 (not full) but I can't turn ON side bars and artifical horizon at all.
Everything else like voltage,naze modes,timers are working OK.
Any tips what I do wrong and what I should change.
Try turning ON/OFF in MWOSD GUI with no luck ..
Shikra
Have you selected a layout where they are disabled?
In brief -
Select layout you prefer
Go into layout editor
Run through and enable / disable the display options you want.
BTW, Upgrade to 1.5 it has support for later versions of CF/BF etc.
marcin
Quote from: Shikra on October 23, 2015, 10:29:02 PM
In brief -
Thanks Shikra.
I just upload MWOSD 1.5 , but was only able to do this with Arduino 1.0.5.
Not working when using 1.6.5 latest version arduino.
Got nice artifical horizon working now :) , new bold fonts are great !!!
I suppose that side bars need full naze32 with baro ?
Shikra
Brill ! Glad you like. There is also a 1.5.1 beta test release available with a few extras. Anticipate R1.6 will be out in 6-8 weeks.
I'll take a look at the latest arduino - frankly it's a pain keeping it so it will compile across all versions. grrrr
for sidebars - they can be enabled with any FC type
If there is baro or gps then get scrolling for altitude change
If there is GPS, can get the other side scrolling for speed change
Cheers!
marcin
Try to upload 1.5.1 ,all goes nice, then I can use MWOSD GUI but trying to upload Layout stop them at 30% and does no go further.
It's reading from OSD board...
Still using 1.0.5 Arduino :)
Pr][nCe
#73
got one of mine to update mwosd 1.5 and using ftdi with arduino 1.6.6. but i get no osd overlay cam says pal and set osd to pal in gui. with no joy. even set to ntsc just incase. vid perfect no osd?
had a major prob with older versions just could not flash it via ftdi or uno. so gave up for few months
one of the 3 i bought is dead for sure.
fc is naze 32 acro , with frsky 4channel with rssi on pin 2 ppm.
Tricopter.  FPV.
2014 Skywalker 1800.  FPV.
Emax 250 Pro. FPV.
Bixler. Night flyer. LOS.
Versa Wing.
Have you got the RSSI connected from the FrSky rx to the board - if you have a look at the last page, you'll see I posted a picture of mine and it turned out that the RSSi connection was messing things up.  I removed it and got the OSD to display
Quote from: Pr][nCe on January 30, 2016, 08:43:16 PM
