my V-tail Quad V3 FPV Build Progress
Started by martink1974, October 12, 2011, 06:18:00 PM
martink1974
Not Posted Much Reciently so thought i let ya all know whats going on in my jumbled brain lol
My first Quad Went well untill i had 2 brave pills one day and it fell from 1500 feet :(
so i built another out of wood this time similar design to see if it helped get rid of few vibrations in first build, this went ok but was too much flex in wood, and my v1 allways flew a little nicer,
i also wanted to go FPV on my quad for a while now so decided to build a v3 :)
this time i decided to use trex 600 tail tubes and clamps to make it a little bit less Heath Robinson
cant wait to get this finished and climb in the cockpit :)
off to get fettlein ...
this build is looking like it will be one tuff cookie, well smart.
:) G
martink1974
#2
trying to make it so
3mm ali composite the plates are cut out of
my plan is that in mishap only the trex tail tubes will bend and are easy changed and cant twist in fittings
made motor mounts plates out of polycarbonate and thinking of doing same for body top and front
having to cross drill everything to save weight
Martin,
What's that red sheet stuff in the first photos ? looks like useful sheet.....
PK
martink1974
here ya go mr pk :)
http://www.sheetplastics.co.uk/Aluminium_Composite/Red_Aluminium_Composite?product_id=1756
i got in a3 sheets can prolly get it cheaper
they use it for signs n like
take care
martin
Handy website....
I've just had another look at your photo's and realised how big this quad is going to be, its a whopper.
PK
martink1974
mark1975
Looking mighty fine.. martin.good heads up there as well..
https://plus.goo
Pasty
martink1974
#9
specs at present :)
4 x 3542 motors 1000kv
4 x 40amp Tornado XQ Escs
2 x 12x8 3 bladed front props
2 x 11x7 3 bladed rears
2 x 5000mah 4s 25c
open pilot copter control board (moving to ArduPilot Mega 2560 after test flights)
Dragon Link RX
WDR600 cam
2.4gig 10mw vtx
OSD ? (still not sure about osd or not Would like voltage and way home if poss)
martink1974
martink1974
#11
started on my smaller v3 quad same design just half size
shall call it
MINI VEE
ha ha ha ha
need sleep :)
do you just set up the controller to fly in X configuration?
martink1974
no m8 ,
im using copter control (open Pilot) wITH custom mix it flys like a tri the 2 motors at the back dont move like tri it just regulates motors at back to control yaw and keep its bum off ground :), the bigger one im using ardu mega controller for and i will use a y4 mixer
i recon you can make anything fly with copter control
thundead
looking good m8 :) love the double boom design :D
