DP106's FPV40
Started by dp106, March 11, 2015, 11:40:35 PM
dp106
Here I would like to introduce my scratch built FPV40 built using a KFM4 Aerofoil.  http://en.wikipedia.org/wiki/Kline%E2%80%93Fogleman_airfoil
Let's see..  Its built from 2 sheets of depron, 2 layers make up the main body and 1 layer top and bottom making the KFM step.  It has 2 6mm strips 750mm for additional strength, not sure if its needed or not..  I've taped the majority of it now apart from the centre section.  This is where the battery, mobius, vector etc are mounted.  Not sure what to do about the centre section, might build up a cover to go over the Vector.
Maiden:  http://youtu.be/anF7NH0EYKs
First FPV Trial:  http://youtu.be/1Or-SlzYh_8
This was a great flight and the first bit of good weather we've had in a while:  https://youtu.be/7ZjoVcxmPi0
dp106
#1
Couple more pictures
Motor is a Sunnysky 2212 1400kv with an 8x6 prop.  Battery is a 3700mah 3s, needed to get the cog right.
dp106
Pretty good for flying formation with a Bixler, Vector was working overtime in places as was rather windy
http://youtu.be/BjSYzleT4dk
dp106
This was from earlier in the week when I snuck out in my lunch hour. Wind was reasonably low so could get down nice and low, I've been trying the Vector in 3D Hold which seems to work well on this wing
http://youtu.be/7ZjoVcxmPi0
