OpenLRS - thUndead's MODs :D
Started by thundead, November 15, 2011, 02:17:53 AM
thundead
Thank you very much for the Beer :) will be used wisely for the upcoming firmware :D
I'm currently working on improving recovery times.
Let me know how the flashing went :D
Mihai.
Quote from: papa_lazerous on November 19, 2011, 01:23:25 PM
Hmm I kinda thought that was the case, serial ppm isnt an option. So I'm limited to 8 channels right now.
I am going to use 1 switch to control my OSD (apparently possible using a 3pos switch) and have pan control only on my cam and use another pot on my tgy9x for the gain on my guardian.  Once I have everything set up and i have proved that the guardian works well and my RTH function works well I will take the gain channel and use it for tilt.  So I will swap everything about, kinda long winded way of doing my setup but it should work.  I have been reading up on adding a head tracker to my radio so with the OpenLRS and your firmware things should be pretty slick.
I have just tested that the OpenLRS all works out of the box with the standard FW on it (ok its on the wrong frequency but I doubt it will matter for 5 minutes in my house lol) just about to flash with 459Mhz FW wish me luck
PS I added to your beer fund as a thanks, as you sent me enough information on youtube replies and are doing allot here. Dont drink it all at once or your head will hurt
John
SouthPawPaul
Now that's odd as I get an RSSI voltage on Servo pin 9 with my v2 hardware unless of course servo pin 9 is actually channel 7?
thundead
hmmm try this:
in the config.h section go to
#if (RX_BOARD_TYPE==2)
and change #define RSSI_OUT 10 //Servo7 or RSSI to
#define RSSI_OUT 12 //Servo9 or RSSI
Mihai :)
thundead
Devonian
#49
I flashed my v1 boards with the RSSI firmware and made a short video of the output (pin 9 on v1 Rx)
I use these RSSI signal strength meter on some of my VTx's:
http://www.dpcav.com/xcart/product.php?productid=16562&cat=0&page=1
You can see the signal strength percentage at the bottom right of the video...
OpenLRS_RSSI_459MHz
I notice no beeps for lost signal packets at the Tx end now - should it be like that Mihai?
Would be nice to retain that I think.
Haven't looked through the code, I simply uploaded your f/w and made the quick test.
I got to about 25 metres and several brick walls in the way in micro power mode - pretty good I think.
Nigel.
thundead
Thanks for the quick test Nigel :)
Nope, its not beeping because the FW is uni-directional so no telemetry.
I'm still improving the FHSS feature so telemetry mode is not a priority yet.
Anyway, everyone uses RSSI on their OSDs and RSSI goes to 0 whenerver a packet is lost or if FS initializes :)
If you feel that RSSi voltage is still jumpy, just play with the RSSI settings a bit :) My RSSI_SMOOTH is 100 now and really happy with it :)
Mihai.
thundead
yup, ch 7 is definitely the RSSI out for the v2 board apparently. I'll have a quick look again over the code and maybe I can spot something lol.
Re-change the code to the original until I figure out what's the prob.
Cheers,
Mihai
thundead
Right, try this
as before , in the board 2 section
paste this over:
      #define Servo1_OUT_HIGH PORTD |= _BV(3) //Servo1
      #define Servo2_OUT_HIGH PORTD |= _BV(5) //Servo2
      #define Servo3_OUT_HIGH PORTD |= _BV(6) //Servo3
      #define Servo4_OUT_HIGH PORTD |= _BV(7) //Servo4
      #define Servo5_OUT_HIGH PORTB |= _BV(0) //Servo5
      #define Servo6_OUT_HIGH PORTB |= _BV(1) //Servo6
      #define Servo7_OUT_HIGH PORTB |= _BV(2) //Servo7
      #define Servo8_OUT_HIGH PORTB |= _BV(3) //Servo8
      #define Servo9_OUT_HIGH PORTB = PORTB  //Servo9 /RSSI
let me know if that did it :)
thundead
Hmmm that is strange.....
I'm looking into the issue now.
SouthPawPaul
I am properly confused.
Your v1 RSSI video shows your RSSI up @ around 2.6v and then drops when you put it in your makeshift Farady cage :)
The v2 boards seem to show a 3.29v RSSI voltage. (confusion #1).
When I read up about analogWrite it tells me that calling this function with a pin number and a value in the range of 0-255 will output a PWM signal on the specified pin.
A PWM signal is a square wave, and the duty cycle of this square wave is altered depending on the value passeed to analogueWrite(Pin#, 0-255); according to the docs.
How are you measuring a voltage drop on a PWM signal with a DMM? As far as I can tell, the voltage should remain constant and the frequency of the pwm signal changes? (confusion #2)
This is hurting my head.  :shrug:
thundead
Yup, I'm getting over 3v in the last FW as well.
THe max output from the arduino is 3.3v and I limited the pwm to 250.
It's not a voltage drop that's the thing. What pwm does is it switches 3.3v on and off very fast.
What the multi-meter sees is a voltage depending on how the PWM duty cycle is.
Same principle applies for motor speed control. You PWM the motor's VCC and motor sees a specific voltage according to the duty cycle.
Hope that sorted things out :)
Quote from: SouthPawPaul on November 19, 2011, 06:24:26 PM
thundead
Ok please try this :
in config.h
#define Servo9_OUT 11 //Servo9
Hope it was that easy :))
Lemme know if it worked.
Mihai.
Quote from: papa_lazerous on November 19, 2011, 05:27:48 PM
getting 0.000v on channel 9 now :(
EDIT
Seems I can put the RSSI only channel 8 easy enough
changing the 12 to 11 meaning...
#define RSSI_OUT 11 //Servo8 or RSSI
It is strange I can move it around from where it was on channel 7 to channel 8 but not 9
thundead
melih's coding is a bit weird. For example, the fw sends 8 channel servo data so in theory channel 9 shouldn't do anything anyway.
Could you please test the FS and maybe do a quick range test in micro mode ?
Cheers,
Mihai.
Quote from: papa_lazerous on November 19, 2011, 06:57:29 PM
Ive tried what you suggested, its a no go.  I posted over at Flytron also about the issue of it being on Channel 7 not 9 and that I cant change it.  I think Melih may have goofed with the coding
Devonian
Mihai,
Would it be possible to simply copy/paste your various bit of code into the fully working OLRS_V_1_10 firmware?
If so, I may just have a go at that over the weekend...(wish I could program properly!!).
Nigel.
thundead
FS aka Fail Safe :) with everything on , hook up a servor or something and hold it in some position. Hold the TX button pressed until it beeps :) , turn tx off and see if the servo goes to where you put it :)
Quote from: papa_lazerous on November 19, 2011, 07:37:09 PM
Test the FS?
