cyclops tornado question
Started by jwmachon, April 14, 2015, 10:11:45 AM
jwmachon
I understand you can set min speed, cruise speed and max speed.
So in pa mode at stick at no throttle what speed would the model fly at also at mid stick and full stick. I don't think the answer is as easy as it sounds
Many thanks
Jonny
AdamG
Quote from: jwmachon on April 14, 2015, 10:11:45 AM
Many thanks
Jonny
My guess was that it trys to go for cruise speed, unless you manually adjust the stick during PA operation. I wish there was a real good in depth guide about every feature on this thing because i find myself just running mini tests in order to determine how it is meant to perform. Im planning on doing a long range flight Thursday and will do a little testing again. If nobody has given you an answer by then i will try and find out for you  ;)
