Compatibility of Hitex X5 with EZ UHF
Started by sterry, January 09, 2012, 02:50:56 PM
sterry
All,
It seems that most people are using Futaba to link to the EZ UHF - i've flown with my 35mhz Hitec X5 system reliably now for years - is the EZ UHF compatible as I would prefer to keep my radio?!
Does your radio have a PPM output?
As far as I know EZ UHF will work with anything that can do that.
Most the Futaba stuff have trainer ports which supply the signal.
sterry
Yeah it has a trainer output - I might just have to find a compatible cable and I'm away....!
Worth checking your manual first for details!
Otherwise if you do have to pickup a new radio you can get Futaba 6EXA's relatively cheap off fleabay.
sterry
Heres the manual for it -
The ports look similar but the EZ UHF states specifically for Futaba - even if the ports are the same does this mean it still wont work...?
http://www.rcgroups.com/forums/showthread.php?t=843235
