A paper glue for foam board ?
Started by weavo56, November 01, 2015, 05:31:08 PM
weavo56
Want to make a kfm 6  wing from foam board (1100mm ) , in the write up he used Bostic glu stik (Aussi stuff ) , has anyone used a good light paper glue other than hot glue with success .I will cover it after with tape .
Thanks  Graham
Quads , 450,550,280's
mini Skyhunter
weavo56
Was also looking at the spray on cans , anyone used them ?
G
mini Skyhunter
mrwilljackson
I've built a depron wing by laminating sheets using 3m 77 spray adhesive: ebay link here
it works really well and didn't dissolve the foam  ;D
You can get a lifetimes supply of bostick glue sticks from here I got a batch for using with my 3d printer  ;)
weavo56
#4
Cheers   mate , just looked at 3m can .
"3M 77 is a multi-purpose spray adhesive that is "foam friendly" and is ideal for laminating paper drawings to Depron sheets or laminating Depron sheets together.
The nozzle has three spread settings so that you can control the spray pattern. You can also control the amount of "tack" that the adhesive has on the bonded materials e.g if left for several minutes prior to bonding, paper can be peeled easily from Depron at a later stage."
Does this mean you can stick the plans to the depron and peel them off after ?
Graham
mini Skyhunter
mp66
Spraying 1 side it should peel off and spraying both is should act like a contact adhesive.
I use Gorilla Glue for my foam builds, you need some pressure while it drys tho... The better potion could be Uhu Por. Again used like a contact adhesive it's good
Fly Foam!                         (and PU Adhesive)
weavo56
Thanks for the replies guys , I have the Uhu por for the depron , will get the 3m 77 and give it a go  for the paper / depron .
Graham
mini Skyhunter
weavo56
Got this glue today (thur )  its a pva type glue .
"Hi-Tack Fast-Tack. Similar to Gold Hi-Tack but with a faster drying speed. Not suitable for washing or dry-cleaning
Suitable for paper, wood, trimmings and household use.
A very sticky glue for fast hold and also fast dryin "
Tried it on scrap foam board to FB  , its repositionable if your quick and  sticks them really well .
Graham
mini Skyhunter
