FlyingWings Hornet Racing Wing
Started by iPeel, December 11, 2015, 08:15:22 PM
Gundummy
That's a very nice bit of kit. Are They on HobbyKing?  ..... Can i have that one...  :D give you a fiver...
iPeel
Quote from: Gundummy on December 19, 2015, 09:21:40 AM
That'5 £5 more than I paid for it, but I'll keep it thanks.
Quote from: iPeel on December 18, 2015, 11:39:21 PM
I'm not worrying about it, it was just an observation; other people read The Internet too.
Are you claiming yanks can read?
Jeez that's a bit strong mate.
Roadrunner
Any further updates on this project, i really fancy a small proximity wing after seeing an fpv bonsai on the x jet channel, will this wing slow up and be controllable or is it just a nutters wing
Nick
iPeel
Yes, I managed to maiden it this morning. It was still a bit windy but definitely flyable.
I still need to get my eye in flying it, it's definitely going to be a lot of fun though! It'll be great at the next FPV meet with a few of these bombing around. I'm not all that happy with the quality of the camera I'm using, it was all a bit murky although I can probably trim the brightness and contrast a bit better through the goggles.
https://youtu.be/sOSDnAFuvlU
I'm glad I watched it to the end, I was egging you on to go through the goalposts!
karlak
Those goals look a lot wider than when I last flew there
;D
Roadrunner
Well i think iam going to order one with the power kit and servos, its near as dam the same price as the HK bonsai and it fits my criterior, i need it to fit inside a sports direct bag, have good flight times and its ready made for micro fpv gear ive just ordered and ive got 4 x 1000 3s lipos
iPeel
Quote from: karlak on January 01, 2016, 04:36:02 PM
Brucey: Just a warm-up as you know so well!
Yeah Simon, the junior goalposts are in the next field, a good 2 minute walk from my house so out of the question today, we'll fly those again in good time!
iPeel
Quote from: Roadrunner on January 01, 2016, 06:26:34 PM
Nice one.
You won't regret it, it flies as well as a wing twice its size. There's not bags of room but the centre section still makes placement a bit easier and strengthens the join compared to a wing without a blunt section.
One thing I would make a note of is not to use a hot glue gun when glueing the servos in place and use Por instead. The micro servos have a really thin case and if your hot glue gun is too hot then it can actually sieze up the gears in the servos.  (?)
Doctor3
Noice !, do you think a 3s 1300mah would slip in it ? as i have about 6 plus of them, maybe with a 2204 ?
www.eddysworkshop.com
At the ready with Duck tape and WD40
Roadrunner
Quote from: iPeel on January 01, 2016, 06:39:11 PM
Nice one.
Thanks for the tip on the servos, is it worth laminating the wing, ive read the extra weight is cancelled out by less drag of the laminate and i hate foam planes for marking or do i keep it as light as possible as i want to slow fly it, the build instructions on the website say to use por for the elevon hinges is this reliable,again i could laminate the hinges in
Regards nick
iPeel
There's no need to laminate it, the three spars make it stiff and you really want to avoid the extra weight. Laminating won't affect drag that much and given the size and thickness of the wing you risk warping, it'd be a really fiddly job too!
The elvons are held on with a bead of Por glue and work fine to create a strong joint. In fact, be careful you don't use too much por. Once you have attached the elevons using Por avoid the temptation to tape over the hinge or laminate, it really doesn't need it.
Roadrunner
Well its on it way, should be here tuesday and thanks for your advise and tips, will post some pics when its built
Nick
luvbus
Ey-up!
