Wing climbing with full throttle. Which way to I bend the motor mount?
Started by Billy_boy_2010, March 13, 2016, 10:38:59 AM
Hi guys
My wing is climbing a fair bit on full throttle. With 40% throttle it flies level. It's well balanced and def not excessively nose heavy.
Which was do I have to bend my motor mount to minimise this? Keep going circles in my head. I think I need to bent the mount so the prop is angled down a little more.
Correct? :) Thanks
Ynot6
 is it going nose up, or is it just rising due to the extra lift that comes with extra speed? if it's actually going nose up, it's got to much angle so the tail is being pushed down. set the motor a little more level.
OMG, IT FLIES!
Failing that you could always mix in a bit of down elevator as throttle goes up.
Quote from: Ynot6 on March 13, 2016, 12:52:30 PM
I would say it was partly a nose up issue. But I expect some of it is the extra lift.
Ok- so I will bend the motor mount a couple of degrees and see if it helps.
It's a Ritewing TW40- such a brilliant and robust little wing. Flys rock solid even though it's quite heavy!
