Finally, off the ground so to speak! Another Tri build!
Started by Nygie, February 16, 2012, 08:09:39 PM
Nygie
Saw them on Rcgroups.com. Not sure if I saw someone here with them also?
Nygie
Finally got the YAW reversed and had time to try the first few hops in the small confines of the garage (couldn't wait for daylight)
http://youtu.be/yIGKRVaQia8
The video should be live in 20 minutes - circa 20:20 hrs GMT
6lennn
10 times better than my first go
im pretty sure its poor form not to crash and burn your first go though, lol
Nygie
Technically I did crash, the prop whacked my roll cab  :laugh: No damage tho which = no burn. Crashed and no burn :P
........until the next time  :o
Nygie
After the trauma with the flight controller, I managed a few minutes in the garden before it started raining!
Trouble with FC was not arming on V2.5.
On 1.6 two motors where lame or one was fast  :o
REflashed 2.5 and it works, ESC's calibrated and has a pretty stable hovver ........EXCEPT
The front right motor seems to be glitching a little???
I have some video, when it's finished processing I'll upload it, you can just about hear the glitching in the motor.
Nygie
And the video will take at least an hour to be live (now 20:51hrs). crappy upload (and HD video :)
http://youtu.be/-v7gG9TXiyo
Listen carefully and you can hear the glitching on the right motor, seems to fly ok tho axcept for the little wobble casued by the glitching.
Nygie
Nygie
With regards the right motor glitching I will check the blades in the morning as I did notice a little nik out of one of the blades.
Nygie
Will do , I've got a spare ESC in case that's up the swanny!
Nygie
Different ESC didn't make a difference, I'll try another reflash, as it never did I before the FC went wonky!
Dizzy
She is looking pretty stable.  looks a good build too, clever idea using those giant cable ties for landing gear  i bet they take a lot of energy out of the odd hard landing :D
dizzy
Los slope
Are your gains set properly? If mine are too sensitive, it wants to fall out of the sky heh
