Another bixler build!
Started by murph847, April 07, 2016, 11:19:13 PM
murph847
I started building my bixler today. Took me a while to work out placing kit but hoping it will all be good. Any tips before I glue it together?
Twinstar 2
Bixler 1.1
Mini Skyhunter to be built
2nd hand Skyhunter for when I have more experience!
murph847
Twinstar 2
Bixler 1.1
I can't really suggest anything, I can't see whats where or what anything is because the pictures are tiny and there is no description to go off :shrug:
murph847
Ah! I will try uploading again,  I selected website size but from my tablet.
Twinstar 2
Bixler 1.1
murph847
Twinstar 2
Bixler 1.1
murph847
First 2 pics are the radio kit and osd,  the last 2 just checking connection lengths and making sure I can get access to battery.
Twinstar 2
Bixler 1.1
Normally you would space out the vtx from the receiver but with 5.8 and 2.4 its not really going to bother it so yeah everything looks ok.
murph847
Thanks for having a look over it. Have built plenty of models in the past, including quads with cameras on, but not a plane so found it difficult getting to grips with positioning the equipment. just hoping I can get it to balance when it's all glued together! Pretty sure I will be able to by moving the battery around, but fingers crossed!
Twinstar 2
Bixler 1.1
I would make sure before its glued. I do it by using masking tape to attach the fuse together, then you can pop the wings on and the lipo in and find out before its too late ;)
murph847
Good idea.....I wish I had thought of that an hour ago..... :-[
Twinstar 2
Bixler 1.1
murph847
All together now, a little bit nose heavy but I should be able to sort it. Slight issue as the rear wing bolt nut popped out, so I have a bit of a job to do to refit it!
Twinstar 2
Bixler 1.1
good luck with it mate. let us know how it all goes.
also, what HD camera is that? looks funny lol
A suggestion for the future.
I've found that for most FPV pusher planes - initially being nose heavy is the norm. I therefore always move the rudder and elevator servos to be re-fitted on the tail section. It moves some weight back - and makes the servos easier to access for maintenance / replacement.
murph847
Cheers for the advice, this is a 1.1 so the servos are already a bit further back, but maybe could have gone a bit further. The camera is a lic ego, thought I'd give it a go as I don't have a GoPro!
Twinstar 2
Bixler 1.1
