First person view pocket dvr settings
Started by scalematt, April 26, 2016, 09:15:17 PM
#15
Any update on this issue? I tried mine for the first time yesterday with the settings as advised and it has failed to record 3 separate 10 min flights and now I have a blank screen.
Update
As it was only 4 months old and only tested in the workshop, I've sent it back to those wonderful FPVUK people.
#16
The replacement arrived and it looks the same. Only difference is it doesn't have the firstpersonview logo on the splash screen, it has vonista, suppose that's the manufacturer.
I noted that RMRC have stopped selling this as there was  "problems with quality control from the manufacturer"
#17
I took some video yesterday and I am trying to download it to Windows Movie Maker from the sd card in a card reader but with no luck.  The file type on the card is AVI which I am sure is the same as the Mobius saves files as. Have I got a setting wrong somewhere?
EDIT
So the DVR records the video as an AVI file, I select the card reader from MM and import the file to the worktop. The audio downloads but not the video?? I have deleted and re installed MM with no change. Grrrrrrr!!
Here is a typical stupid noob question. I have been using the recorder using the internal battery, which is now flat.  I cannot find anything in the manual that tell me how to charge it? I dont want to plug anything in in case I cluck it up! I have the AC adapter so do I just plug the USB lead with the round pin into the dc in socket and the other end into the adapter? And if I do what should I see led wise?
You need a 5v DC of 500ma rating. When you plug it in the green charge LED will come on.
Ok so I just plugged the supplied lead that has USB to round male pin into the Supplied mains adapter and the other round end into the Dec in socket. I now have the number 2 charge led on and the bright blue led on. Does that sound OK?
I would add that my DVD recorder from FPV does not have the FPV logo but vonister
Mine didn't cone with a USB to DC jack just an adaptor. Chant remember two LEDs being on while charging.
Dillwhacker
#22
You just reminded me - mine needs charging  :o
Yes, green and blue when charging.
I think one of them goes off when fully charged.
Edit - the blue one goes out when it's charged.
