First person view pocket dvr settings
Started by scalematt, April 26, 2016, 09:15:17 PM
scalematt
I bought a Pocket DVR from first person view. Im looking for info on how to set it up for best quality to record FPV. What settings and memory card do you use? Also have you updated any firmware?
You do not need it on high quality, it's a waste of time and with static on 5.8ghz can lock the unit up.
Instead select medium quality ( which you won't be able to tell the difference with ) and the lock up won't happen.
I have the audio set to record from the internal mic because it can pick up some very funny conversations from the ground during the flight.
If you find a tiny bit of tearing at ghetto top corner which I did with one of them I found recording with 2 bars of battery instead of full fixed it........go figure :shrug:
I have three of them and the other two don't do it.
scalematt
cheers for that, what about resolution?
scalematt
I'm out so I forget, they have a few odd ones but pretty much 640x480
I bought mine from readymaderc, and they claimed to have loaded it with custom firmware that got rid of the 8500kbps bitrate and instead, the highest it would do was 7000kbps... the image quality was still outstanding and it was quite frankly the best DVR I ever had (till I sold it to Ian lol).
I have mine handy (it's the BevRC one, but it's the same thing with a different splash screen)
Resolution: 640x480
Video Quality: Medium
File Length: 5 Min
Frame Rate: 30 FPS
The reason I use the 5 Min file length is because I have had a few lockups, and having to reset it has lost my entire file (sometimes >30mins) so 5 mins file lengths keep me safe.  Of course it hasn't locked up since I set it
scalematt
Cheers wayne. Looks like my DVR will be going back as i think its died. Screen totally blank.  :censored:
Is it ?
You were not by chance playing with the AV output setting of it at the time ?
When you activate this the screen goes off. Normally you would have a screen plugged into it so you can still see the menus but if not you're just stabbing around in the dark.
scalematt
That was the first thing i thought , so i plugged the cable to the av out and the the av in on my goggles and still nothing.  :(
I'm assuming you have reset it with the pin to put it back to default settings ?
scalematt
It was on charge. Worked before it went on charge. Unplugged it and switched it on and no screen. Gutted.
scalematt
Yes tried that while the power light was on. Nothing happend.
scalematt
I will try it all again tomorrow just to check i have tried everyway.
You may have to start up a support ticket with fpv.co.uk then. They really are good units, I have had 4 altogether, 1 broke ( FPVJapan version ) after a firmware update, the others ( firstpersonview versions ) are all still alive and kicking maybe two years on now.
