Recommend a cheap autopilot.
Started by mrorange26, May 14, 2016, 09:00:44 PM
mrorange26
Could anybody recommend a cheap autopilot for my falcon that i am building.I have bought  a Feiyu Tech FY-41AP Lite off a friend but i have my doubts on how good they are after reading some forum threads.It will be being used on a 9xrpro controller with a L9R receiver.
mrorange26
mrorange26
Are the turnigy ones any good also seen this one
Bigaole BGL-6G-AP
I've never heard of or seen that one before.
Antkol
Hi there.
I've just installed a cyclops storm into my Bixler 1.1 this afternoon.  I wanted a cheaper alternative to the eagletree vector that I have in my Skywalker.  The Storm is excellent and very easy to install.
The only diy bit you need to do is to solder some fittings on to the current sensor (I used xt60's).
The menus are easy to work with.  The only downside on my setup is that requires more space than the vector.  As a result the inside of my Bixler looks like the control room of Bletchley Park.
Went for a test flight on default settings  and it flew great.  It was a bit gusty but coped well.  The osd is well laid out too.
It is IMHO not as good as the Vector but it is half the price.
I would recommend it.
Mini talon
Skywalker 1900
Bixler 1.1
www.personalisedgoodies.co.uk
mrorange26
#8
If you decide to sell the fy41 let me know. We have used the fy41 heavy for 3 years now and after some steep learning curves we have it working fine. It has some weird issues regarding booting up correctly every time. If you get the command switches in the wrong place n the tx or boot the AP before the tx it will change the default cruise % to 212 which is outside the parameters, then when say RTH is selected the computer just shuts the motor down! However, as said, if you set up using the FY GCS, use the airspeed sensor and calibrate it, it works OK. Oh, and the back up from FY Tech is non existent.
My AP of choice is the MFD which has been rock solid, but it's not cheap! Oh, and the back up from MFD is now crap as well.
Edit
I know of some club members who are still using the Panda2 and DOS units.
mrorange26
The one I have is the lite version
mrwilljackson
Quote from: mrorange26 on May 14, 2016, 09:14:58 PM
Bigaole BGL-6G-AP
I have one of these,  dead easy to set up and works well. Doesn't have an osd though, so go for a storm if you want that ;)
Miles
Wings: 2*X6, 2*X8, Z84
FW: Wot4, EZ*2
SZD Pirat 1:1
jimbo19
Just bear in mind if you go for the storm , no PPM and no throttle control either ,
so make sure you set failsafe on your tx with throttle that you want
mrorange26
Is that the same on the one I already have the fy41 lite
Quote from: jimbo19 on May 15, 2016, 12:37:07 PM
Actually, the Storm OSD does support PPM.
