jt's Mini Talon Build.
Started by jt, June 03, 2016, 11:59:00 AM
jt
 Yeah, that's the point really, I don't know how far this will go, a lot depends on how long the 8000mAh 4s will fly. I've got a circular wireless cpatch to go on my tracker too, so certainly overkill for my current ambitions but they are of course always fluid lol.
I do often look at the ships going past, I think they are somewhere in the vicinity of 12km out from here, that is always in the back of my mind but would require lots of over the land confidence in the gear lol.  Capability to go twice the distance you actually fly is still no bad thing lol.
Quote from: BlueFlyer on June 27, 2016, 04:51:38 PM
EzUHF will do 5km with a rusty coathanger stuck in the SMA port lol (I've heard someone say :) )
LIAR! ;) Just ask my crumpled Z3! :P Complete signal loss at 2.2km for me with the stock antenna and a dipole on the Rx. I suspect something else may have been a factor there though, it seems to be against the norm.
Shouldn't have issues where the antenna is I wouldn't think, apart from it will get a bit of a beating on landings! Got a thingiverse link to that module holder? I like the idea. Did you just make up a cable extension for the connections?
jt
Quote from: iwan_canobi on June 27, 2016, 05:24:58 PM
It should be OK, I used 1.2mm braided bike cable, it should spring right back to shape.
Quote
Here you go   http://www.thingiverse.com/thing:1148788  Yeah just made up a cable, you do need some fairly long header pins for the module, I used some of the long angled ones that I got with a naze board once  :)
jt
 Glued the fuselage.......finally  :laugh:
I used the wooden hatch nut holders sandwiched with another bit of wood on to keep it all aligned, when I took the bolt out this morning the bloody nut fell out of one!!! Not that I wanted to use long bolts every time I want to open the hatch,so will be thinking of a better way to hold it on.
jt
 It's done!  Just need to power it up and test everything, level out the control surfaces, put in the battery and fly!
Thats looking good jt, when is the maiden?
Quote from: jt on June 27, 2016, 06:23:10 PM
Awesome, cheers!
jt
Quote from: iwan_canobi on June 29, 2016, 01:11:25 PM
.......when is the maiden?
Soon, I hope lol. The weather forecast isn't looking great, 30mph winds for a few days, still it does sometimes drop off in the evenings(wishful thinking), other than that I'm rearing to go!!!!
Andy Sayle
Good luck with the maiden!
How are you retaining the battery in place?  Velcro strap?
jt
  I'm just going to go for self adhesive velcro and gentle landings lol, the 8000mAh 4s isn't exactly small or light but asides from crashing it should be ok......
Quote from: jt on June 29, 2016, 12:34:37 PM
Glad to see you have the missus in her place in the kitchen while you dick about with planes:D
Jake Bullit
Good luck with the maiden.I'm on the same boat,just waiting for a break in the weather.
It's been loaded in the truck every day this week.
Maybe tomorrow?
jt
Quote from: Jake Bullit on June 29, 2016, 03:53:49 PM
Maybe tomorrow?
It's a race to maiden then lol!  Looking at the 7 day forecast it's 20mph plus for the whole coming week :(   I know this will fly in that but need it a bit stiller for a maiden, especially as she is a bit of a fat bird weighing in at 1.7kg  :laugh:
jt
 Testing out my headtracking pan with my little 'assistant'  :laugh:  It's using this little servo from banggood, interestingly it doesn't have a stop point so would probably rotate a lot further.
http://youtu.be/MV1gQ3lsKII
Jake Bullit
jt
 You did you bugger!!! It's windy as hell here today!!!!!  Glad to see it went so well, not sure about your 'landing' though...... :P
