thUndeadMod v3.4 - openLRS S**T just got real :)
Started by thundead, February 25, 2012, 02:16:24 AM
Any Bugs So Far ?
Nope, thing is rock solid!
This hopping algorithm is rubbish!
I want More options in the config app!
I'm still using the stock FW
RSSI Is Awesome !
RSSI is rubbish!
Range is amazing!
Range is ok I guess
Range is crap
thundead
if u bare with me 10 mins then yes :D
Quote from: webe on March 26, 2012, 11:06:39 PM
Yey! Good news!
Should I cancel my trip to my bed? :D
Why does mine appear to be working then on ground test ?
thundead
no friggin idea! I've hooked mine on the multimeter and its either solid 3.28, 1.4 or 0. very very weird but I found the problem and fixing a solution for it :D
Quote from: Coyote on March 26, 2012, 11:08:09 PM
Ah well that tally with my ground test, it was 1.4 at 4km, hmm, I really will have to repeat the range test for sure now. I know its good for that range, but with fully working RSSI I might be in for a nice suprise
webe
Coyote,
on which band you'll be repeating ground range test?
I'm getting ready to do it on 433 using stock OLRS antennas and stock DragonLink antennas I've got today from Virgis21.
Cat695
Guys I really need help with flashing the firmware
I get no error message...just 'done uploading' but the light on the Rx is solid bright red
I've been going at this about 2 hours now
webe
It should be solid red until RX sees valid packets from TX.
Double check config for you TX and RX. Must be same band, same channels count, same channels and same header chars.
Quote from: webe on March 26, 2012, 11:15:39 PM
Coyote,
On 459@100mw
Cat695
Quote from: webe on March 26, 2012, 11:19:47 PM
I'm slapping myself......so i did it right the frickin first time :'(
I haven't done the TX yet!!!
Solid rx means rx is on, blue means its reading the tx, so one doesnt match the other, check your headers and bands match, and set no.
webe
Quote from: Coyote on March 26, 2012, 11:20:56 PM
Coyote,
What antennas are you going to use?
I'm very interested to see difference on 433 and 459 :)
On 459@100mw
Well RSSI may not tell me much if it wasnt working. All it will confirm I suppose is 459 will go 4km+ on the ground
Quote from: Cat695 on March 26, 2012, 11:21:52 PM
Ah, go into the corner and have a quiet word with yourself lol  :)
Cat695
I think so....frickin newbies heh
The FTDI flashed like a maniac for awhile then the rx turned solid red
