Laser Drak mini
Started by beesleyboy, February 13, 2017, 11:51:23 PM
beesleyboy
The receiver turned up today, so tonight I got it all running, i'm well pleased with the power, it lifts vertically, so as long as it fly's, it should go like a rocket.
i need to fined somewhere with long grass tomorrow, for its maiden flight, I haven't got a clue where the CG is.
LOS not enough room. ;-)
Oo looking forward to this G, make sure to record a video
Badlands
Looks like the same power plant as the Wii Wing?
Superb job G - cant believe how quick you have knocked this up - GL with the maiden - cant wait to hear the outcome.
beesleyboy
#18
Well, you win some and you lose some, strange behavior, first of it seemed front heavy, so I moved the battery back slightly and it tumbles backwards side ways and whatever way it wants to, like a leaf in the wined. not to sure witch way to go, seems like a dart without the flights, not sure weather the motor needs pitching, or I need more elevation.
I have a short video, that I need to put up, but I will need to make some changes, if this little plane is going to work.
G
https://youtu.be/nQFihZ8I8Q8
CoG on the original one is about 1.25 -> 1.5" in FRONT of the FRONT spar... not sure where that'd be on your scaled up version.
Badlands
Argh Damn G! - it did look like a CoG problem but what do I know.
Hope you will stick with it bud.
beesleyboy
I was thinking it was CG, but when I move the battery from front to back in small movements, it still misbehaves.
perhaps there's a flying guru out there, that likes a challenge, I could send them a kit, see what thay can do, i'm a model maker, not a airo dynamics expert. Lol
I will have a look agen soon.
lots of work on at the same time, getting an art instillation ready to go to Milan.
Badlands
I would love to have a play G - ill pay for the kit regardless whether it fly's or not - gimmie your PP addrss bud.
Spikeons
This looks pretty awesome if the 600mm one comes out I'm definitely interested.
Jack
Dillwhacker
Quote from: beesleyboy on February 18, 2017, 01:15:37 PM
strange behavior,
Eeek, that's a twitchy little beggar..
Well I'm no expert but apart from the obvious rearward COG, I'm thinking..
Is it just stalled and needs to get up more airspeed?
What is the wing section and wing loading? - is it reasonable for such a small model? If the section is thin and flat it will have to get shifting  before it becomes stable & responds nicely.
I don't know how forward swept wings work really - does the real DRAK have a very thick section? or reflex? Or tip washout ?
Finally - how stiff is your wing? If it's flexing in flight, then the responses will be - well - interesting..
Good luck with it, love it and hope to see more  ;)
beesleyboy
Quote from: Dillwhacker on February 18, 2017, 11:58:53 PM
Hi
lot to answer there, The plain is 45g with battery fitted, the wings are stiff with carbon running through them, it has a shaped air foil wing and I haven't got a clue what the big Drak has.
beesleyboy
Quote from: Badlands on February 18, 2017, 11:17:27 PM
Mate, I will cut you one for nothing, if you are willing to give it a go,
just pay for the post, I think I have your address in my messages, I will let you know when I have one cut out ready to send.
;) G
Badlands
Quote from: beesleyboy on February 19, 2017, 10:10:48 PM
;) G
G - YES please - ill pay shipping np - thx bud!
Schalonsus
Quote from: beesleyboy on February 18, 2017, 10:06:14 PM
Try moving the battery forward: Nose heavy flies bad, tail heavy flies just once.
beesleyboy
Quote from: Schalonsus on February 20, 2017, 04:30:37 PM
thanks for the advice bud, yes I tried that, I thoght the exact same thing, but I think theirs more to it than that.
I need to get back to it soon.
G
