Laser Drak mini
Started by beesleyboy, February 13, 2017, 11:51:23 PM
Schalonsus
uhm, maybe the thrust angle of the motor?
And such little / light weight planes dont like wind at all, maybe you could try it on a very calm day or indoor.
Wings often don't have a very large flyable CG range, it may be that at the point between those two very different behaviours that it might actually fly.
beesleyboy
Bit late Martin, but hear are some of the process photos.
LOS not enough room. ;-)
Badlands
G kindly sent me this beta kit.
Although some parts needed cutting & some parts needed making im still amazed at how well it came together & how accurate it is.
I'm determined to get this to fly - just gotta add the electrics & chuck it!
Ok can I go into the queue for a 600mm version please G, I think I'd like to try one of these - they look brilliant.
beesleyboy
looking great Martin, I reckon next time I try it, i'm going to try a flat wing, with no airfoil.
beesleyboy
Quote from: Steve W on March 05, 2017, 12:59:51 PM
I'm away for work from Tuesday Steve, but when I get back next time, I will start looking in to the 600mm.
It does look really nice.
beesleyboy
Badlands
After many failed launches I seem to have found the sweet spot.
I increased the thickness of the wings & added a 'ton' of elevon reflex.
With the battery waaay out in front - it flys!
Large dots indicate current CG point.
There doesn't appear to be enough elevon authority - so I may have to make larger ones.
Also the thrust angle is out on my build.
It looks awesome in the air thou...
Well done G!
This is a fun project now...to be continued...
Schalonsus
This thing is ripping through the air :o
FlyingRock
good job! feels like it flies great!
Schalonsus
When available and what will it cost?
Ratty
Nice work guys. Looks like you got it sorted Martin.
You will be missed tomorrow buddy. Dont forget to come race me sometime this year.
