Help finding Wires for VTX
Started by DS123, February 28, 2017, 11:13:38 AM
DS123
Can anyone help me find a plug in wire for the Eachine TX526 or (Eachine TS5828). I need to buy another plug in connector but can't seem to find one anywhere?
I did find these:
http://cpc.farnell.com/jst-japan-solderless-terminals/zhr-5/housing-crimp-receptacle-1-5mm/dp/CN18345
Which I think is right but really don't want to go down the route of having to make the cabe up myself.
I also mostly but from BangGood and AliExpress, where do you get your parts from in the UK?
Dave
I'm 99.9% certain I've got one of those back at HQ. I have quite a few Eachine bits & bobs lying around.
I will have a look this evening.
Did you want just the plastic or do you need the wires too?
DS123
I was looking for one with wires which would be great if you could help. I already have a massive box of bits and I'm still quite new. I guess this grows and grows the longer you've been in the hobby!
DS123
Dave
Does this look like what you need?
Its definitely Eachine, probably from an ET25. The actual plug bit (not including the location bars) is 7mm.
If its any use to you PM me your address and I'll pop it in the post :)
DS123
Just in case anyone else wants to get this part I can confirm that the following works:
https://www.aliexpress.com/item/Mini-Micro-JST-1-0mm-5-Pin-Connector-with-Wire-x-5-sets-100MM/32699620557.html?
The wires are in the wrong order and not nice silicone wire but at £1.40 for 5 you can't grumble.
