What's wrong with my Dvr?
Started by danbt, April 07, 2017, 07:11:39 PM
danbt
Hey guys,
Just put together my fpv system and its working, hoorah!
However, the DVR isn't.
I take output from vrx, goes into the Dvr with the headphone jack type of wire but with 3 rings on the shaft, then output goes into my quanum goggles screen.
The Dvr powers up but I get just get no signal on the screen. There are 3 green leds and one red. One green and one red just flash continuously.
This is the HD DVR little silver box that a lot of people have.
Any ideas? I think it's faulty.
Sent from my ONEPLUS A3003 using Tapatalk
Try pulling the cable out slightly, some of the devices expect the cables to be wired a certain way so the 3 rings are in the wrong order. Worth a try anyway, that's what my DVR has an issue with.
Drone 5
#2
This is a copy from a few years ago when I uploaded it but it may help.
I had the same trouble a few weeks ago after getting the pocket DVR from FPV.  At first I used these "Gender changers" (3) to connect from the 3.5mm jack Fatshark attitude goggles cable to the the 2.5mm jack cable.
http://www.ebay.co.uk/itm/Single-RCA-Phono-Coupler-Joiner-Female-Socket-to-Socket-Gender-Changer-Adaptor-/220901607116?ssPageName=ADME:L:OU:GB:1123
I wanted a light weight cable so I got a 3.5mm jack cable to a 2.5 jack.
http://www.ebay.co.uk/itm/4-Pole-3-5mm-Male-to-2-5mm-Male-Jack-Cable-Audio-Lead-AUX-MP3-PC-Stereo-AV-DVD-/251248740078?ssPageName=ADME:L:OC:GB:3160#ht_690wt_958
This standard cable did NOT work as the wiring is different.   I cut the wire and re-soldered them and it works great.  Attached is a drawing of what cable goes to what.  Hope that helps. The sound is only mono.
Pm me or ask on here if you want more help.
Modify message
M.
YouTube Channel     wad5uk
Drone 5
M.
That's some great info Drone 5, have some karma :)
