1.2/1.3ghz vtx and vrx system
Started by hellsbells1, April 20, 2017, 04:52:50 PM
hellsbells1
Hi can someone give me a link to both vtx& vrx best out there at present please?. 1.2/1.3ghz possible with good filters installed 800mw please? . Thanks trevor
SnoozeDoggyDog
You could try the readymaderc.com vtx and vtx. That's supposed to be good quality.
I'm using the Partom 1.2/3 and i have had no issues past 3.5 miles. My nerves are my limit so far!
P
Mini Talon with Vector AP
Reptile S800 Sky Shadow
LawMate 1.2G Video reciever high quality, still obtainable from Goodluckbuy....
Compact size, no extra filtering required, not cheap (about £60)....
SnoozeDoggyDog
I can't bring myself to order from goodluckbuy .... the name doesn't full me with confidence  :+
Quote from: SnoozeDoggyDog on April 20, 2017, 08:30:46 PM
Had a few things from them, never had a problem...I tend to use Survielzone these days for vtxs...
hellsbells1
forgot to ask with 1.2ghz would i have problems useing dragonlink 433mhz?
chris-s
... and hijacking your thread, what wattage is preferable since we usually put the emphasis on good antennas.
chris-s
Actually, after looking at what GLB have to offer, which set would be best to get?
GlenJacob
Quote from: hellsbells1 on April 21, 2017, 01:51:13 PM
This is highly unlikely if using the 'new' NextGen software (which is no longer new as it's like 5 years old).
And even if there are problems, it is likely your DL causing issues with video as UHF harmonics fall on 1.2/1.3. :)
Schalonsus
Will be cheaper to get the VTX's from SurveilZone. Very fast shipping too.
Can recommend the 800 9ch and the 200 4ch.
For RX there are just three options: RMRC, Lawmate or DalRC
All three are brilliant. The only disadvantage of the DalRC it has a different audio filter frequency, so with the standard transmitters you will have no audio. You could solder the right filter in.
