AKK Technology Coupon Code Sharing
Started by Dennislee, September 15, 2017, 11:03:19 AM
Dennislee
Hi everyone, I have a coupon code from AKK Technology Official Website to share with you guys, period of validity: Oct 12th, 2017
CODE: akk10PERC   , you could save 10% on the basis of 26% discount, chek it out! GOOD LUCK!
Dennislee
Dennislee
#2
New product AKK X2P 5.8Ghz 40CH 25mW/200mW/500mW/800mW Switchable Betaflight OSD FPV AV Transmitter with Pigtail
product link: http://www.akktek.com/akk-x2p.html
AKK X2P:
25mW/200mW/500mW/800mW power switchable
7-24V input and can be provides 5V output for your camera.
Can be filter the power and make sure you get clean video.
Super mini size and light weight,One button frequency and power setup.
Support parameter adjusted and work with Betaflight,fligth controller,OSD
Specifications:
Input voltage: 7V-24V
Power supply: 5V Camera @ under 0.3A max.
Output power: 25mW: 100mA
200mW: 180mA
500mW: 250mA
800mW: 300mA @12V
Range: Up to 4 km with omnidirectional RHCP antennas
Port connector: JST, 6pin
Antenna connector: SMA female
Package includes:
1x 5.8G X2P  transmitter
1x Cable
1x Product manual
Dennislee
#3
AKK F4 Flight Controller with Integrated OSD only 18.75USD :https://www.akktek.com/akk-f4.html
Specification:
Weight: 5.6gram
PCB Thickness: 1.2MM
Processor: STM32F405RGT6
Transmitter: MPU6000 integrated accelerometer/gyroscope
Preset firmwareversion:3.1.7-OMNIBUSF4SD
Signal of receiver supported: PPM/SBUS
Onboard memory capacity: 16MB
OSD: Flight Control Board IMU with Integrated OSD, support ground station Betaflight OSD parameter configuring; support tunning PID with OSD by using remote controller; Transmitter power, frequency band/CH can be tuned with OSD based on the Betaflight.(Support FPV transmitter like AKK X2/X2P)
Dennislee
AKK X2 review video, thanks CurryKitten
Hey, I know that guy.  He's very handsome, and everyone should do what he says :)
(review was already posted up in the Product Review sub-forum BTW http://www.fpvhub.com/index.php/topic,52434.0.html)
Dennislee
Quote from: CurryKitten on October 18, 2017, 09:56:51 AM
Thank you, CurryKitten
Dennislee
#8
Well, AKK Technology has upgraded AKK X2 to FX2 to make it adaptive to FPV markets :)
check it out: https://www.akktek.com/products/akk-fx2.html
Key features:
Support Parameter-adjusting mode
25mW, 200mW, 500mW and 800mW power switchable
OSD configuration using FC Uart
7-24V input with 5V output
With MIC
Button control Channel select mode:
Channel select mode
Band select mode
Power select mode
Package included:
1 x 5.8Ghz 40CH 25mW/200mW/500mW/800mW Switchable FPV Transmitter
1x Antenna and cable set
1x Product manual
Specifications:
Dennislee
Dennislee
Good news. AKK Aliexpress store all of products 24% off https://goo.gl/Ki1YwF
Dennislee
Spam account deleted.
You start spamming other topics again and your reviews, accounts and manufacturing thread will vanish too.
Dennislee
