Scale Hughes 500MD Defender NAZA-H T-Rex 600 FPV Build
Started by Njoro, October 20, 2017, 02:31:54 PM
Njoro
I have 2 fuselages larking in my loft workshop that will take a T-Rex 600 mechanics, I've decided to start with the Hughes 500MD to see how I get on.
Parts required:
1 x Scale Fuselage.
1 x Second-hand T-Rex 600E
1 x 5.2Ah 22V lipo
1 x 7.4V 3Ah Lipo
1 x UBEC
1 x DJI Naza-H Gyro
1 x DJI OSD, in hand; I'm yet to test it to see if it will work with Naza-H.
1 x FPV camera, I have a choice of 5V or 12V
1 x Flybarless Head
1 x Set of semi-symmetrical 700mm carbon rotor blades, in hand.
1 x EzUHF RX, optional
1 x EzUHF 5.8 VTX.
1 x 2G4 Vtx, optional
Came with the helicopter:
1 x Set of carbon tail rotor blades, binned they are too short and they are chipped.
1 x Set of Maniac 600mm carbon main blades.
1 x 100A ESC came with Helicopter.
3 x Futaba S9252 coreless servos.
1 x Align DS655 tail servo.
3D Printed Parts:
1 x Naza-H housing
1 x EzUHF RX and 7.4V lipo combined housing.
;D
Njoro
Drawings are done and the first print just came off the printer.
Njoro
Njoro
#3
"A bit more progress"
The loser the FC is to the CG the better the overall perfomance.
Next; I've also decided to change the belt drive to a torque drive which should make the installation into the fuselage easier.
Njoro
Njoro
I've started the mock-up now and in the process of printing a mounting spacer.
The fuselage
The H looks like it takes a lot of stress and bills out of the whole process :)
Njoro
Quote from: Coyote on October 24, 2017, 04:48:11 PM
Hi Ian
It's really assembling, and printing stuff that is usually velcroed in place; I've printed a few more bits and I'm nearly finished with the Gyro setup.
I had an issue with the flybarless head which has snap links that only go one way, which has meant the blades are out by 1/2 a turn. Align doesn't make the turnbuckle for the old T-rex 600 which has longer pushrods, I'm looking at other alternatives.
PS I've been unable to upload pictures for some reason, I'll try later though.
Njoro
The battery mount brace is done now but there is a little more work to be done.
I originally had the Hirobo GPH346 in this body which has a wider footprint hence the 3D printed adaptor brace at 100% infill.
A larger GPS module off one of my copters has found a new home, this GPS is much faster in acquiring satellites than the DJI one.
Njoro
Hot off the printer a swashplate leveller a critical part for setting up in the GUI
Njoro
I came across these spirit bubbles in the workshop, the MKII level is born ;D
