Skywalker build
Started by MarkLincs, March 16, 2012, 01:59:28 PM
MarkLincs
I've been busying away with my skywalker build 1900mm
Now I've done some Mods and who hasn't!
My main ones so far are the Ailerons adding in proper wing hinges 2 on each Aileron
I cut slots in the foam and super glued them in then added some fibre tape on top as a just in case.  Then the main Aileron control hinge is no longer push into the wing and hope it doesn't pull out. A layer of fibre tape then 2 screws through the horn to a plastic stop the other side and the same for the rudder and elevator.
Main hatch for access to internals cut on both sides.
Magnets now hold the canopy in place.
The wing is now one piece glued together, no way could you leave it a 2 piece wing, you couldn't trust it.
- Still learning every day -
tdmodels
#1
Hi Mark,
Looking forward to your build thread. My build so far seems pretty much the same as yours - magnets on canopy, one piece wing  etc.  Really must finish my thread even though I have flown it many times now  :-[
N.B.  I had to pack up on one side of the fin to make sure that the tailplane was level with the wing!  Also added reinforced tape to the underside to protect on landing.
FPV God
that's farther than me guys, I took my won out of the box, and looked at it for ages.
;) G
MarkLincs
Well if I push on with it may make a maiden for sunday...
needs rudder sorting and elevator next and its defiantly getting some fibre tape on the underside to help protect it!
Elevator looks like it could do with proper hinges but the carbon rod gets in the way...  not sure what i'll do to it yet...
tdmodels
I left my elevator as standard, but just put a 1" wide strip of fibre reinforced tape along the hinge line on the top side. Been fine so far
FPV God
MarkLincs
Looking good Mark, is your tail straigh, ive never had a straight one yet ? :)
MarkLincs
Quote from: Coyote on March 17, 2012, 12:34:46 PM
Looking good Mark, is your tail straight, ive never had a straight one yet ? :)
it is as bent a 2 bob note :)
Lol, you think they`d get it right after 5 versions lol
MarkLincs
Test flown today....
can turn left okay but not right...
flys okay on rudder though....
MarkLincs
These are my new and improved control links :)
Hopefully these will solve any issues :)
MarkLincs
Another test fly today, better but still won't turn left/right correctly...
Fixed it with a 20% Rudder mix with the ailerons
Now turns as it bloody well should do!
I just use my thumbs, good piloting discipline to do it yourself :)
Good to see you change the crap linkage hardware, the stock gears terrible. How about some videos ? :)
MarkLincs
Quote from: Coyote on March 23, 2012, 06:31:31 PM
I could do it myself but cannot be arsed, the tranny can do it so let it  :D :D
Needs final tests any FPV system tests tonight and then battery charge for maybe just maybe a flight Saturday/Sunday....
Depends though work work work :(
papa_lazerous
I do all my rudder aileron mixes manually because when I learnt to fly it was on a radio that couldn't do mixing lol good luck with getting a flight this weekend, I'm aiming to get airborne also with the skywalker
