Rxsr binding and firmware issues
Started by ali101, May 20, 2020, 05:27:32 PM
ali101
Hi guys,
I've just got a new rxsr with EU firmware from hobby Rc . My radios FCC so I've flashed the FCC firmware on the rxsr but it's still not binding. Maybe I'm using the wrong firmware on the frsky website as there's ACCST and ACCESS under RXSR?
Any ideas which ones I should be using or any advice on getting it to bind?
Thanks guys
ched
First off to flash the fw you need to know what your radio uses ACCESS or ACCST. Then flash the according fw. Also the pins on the r-xsr to flash are not the same as the ones used to connect to FC.
Hope that helps?
ali101
Okay thanks, I've solved the issue by using the older firmware on the FRSKY website for the ACCST instead of the newer one.
