How to Charge a 7.4V 2S1P 3500mAh 18650 Li-ion Battery Pack
Started by wgt40w, November 10, 2020, 12:36:23 AM
For the first time I have ordered some made-up packs of 18650 Li-ion cells.
I aready have a charger to charge individual 18650 cells, but am not sure how to charge a made-up pack, such as a ZOHD LIONPACK 7.4V 2S1P 3500mAh 18650 Li-ion Battery.
Can I use a lipo charger, set at a very low rate ??
Drone 5
You can charge the 2s 18650 pack as if it is a Lipo Battery with the standard battery charger. I set mine to charge at 1 or 1.5 amps and the balance lead plugged in. You can charge each call to 4.2 volts so a standard Lipo charger is fine.
M.
YouTube Channel     wad5uk
Drone 5
M.
