Failsafe for EZUHF
Started by 6lennn, April 12, 2012, 10:41:58 AM
6lennn
The EZUHF doesnt have a built in failsafe that I can see so can anyone recomend one, or are they all much of a muchness??
cheers
ps I need it to do 3 things, set throttle to cruise, switch on stabilization, and swith on autopilot, does this mean i would need 3 failsafes?
6lennn
Quote from: Balders on April 12, 2012, 10:53:14 AM
Can it not just be set to preset stick/switch positions?
Sent from my GT-I9000 using Tapatalk
thats what im trying to figure out....
6lennn
wgt40w
The following is Copied & Pasted from the EZUHF Manual:
Failsafe
If, for any reason, the UHF link is broken, the receiver will wait for approximately 1 second for the link to be restored, and then will enter failsafe mode.
The failsafe servo positions are programmed using the button on the transmitter.
To set this up, two phases are recommended.
1) With the plane on the ground, and servo positions neutral, throttle cut, hold down the transmitter's bind/failsafe button until the transmitter beeps. This will set a reasonable default failsafe ready for the first flight
2) With the plane in flight, set the controls in a suitable position for the failsafe, and re-program the failsafe. In most cases, 'suitable position' means throttle cut, and a gentle turn radius, to let the plane circle gently until it lands, but of course every application is a little different.
dogzilla
lol? it says it on the product.
6lennn
wgt40w
How did you know my middle name ??
