Got my ezUHF! Drivers?
Started by markvanhaze, May 27, 2012, 11:53:43 AM
markvanhaze
So I got my package from Simon and want to install it. It looks all straight forward but I was reading the forum just to make sure and now I see that there is a firmware update option. Do I need to update?
markvanhaze
And another newbie question: Where do I connect my UBEC on the EZUHF RX?
markvanhaze
Figured out that you can connect the UBEC on any available channel of the RX. Still dont know if I need a firmware update though.
Ezuhf updates tend to be for using different / extra features. Check on ImmersionRC.com to see if any are for essential updates, but if you have bought it recently then they will be up to date anyway
Ubec to a spare channel, or if you have none, share the throttle channels with the ESC signal wire
Malcr001
I bought my ezUHF a while ago now but I have yet to actually power it up and bind it. Im using an MK FC, the FC supplys 5v to the reciever via a servo connector. If I connect this servo cable to ch1 that should power it up right?
markvanhaze
#5
Thanks, sorted all that.
But now I am hitting a wall and need help, again. I have a 7channel Futaba and thought I could use ezUHF with FY31 and Hornet OSD and a pan and tilt system using the FT HT. Am I asking for too much? Do I need more channels to run all that?
From what I see, the OSD wants a channel for switching modes, FY31 wants 2 triple state switches/channels, pan and tilt needs 2, and for flying I need rudder, elev,aeleron,ESC. So totalling 8 and I only have 7.
So im a little confused now, its been a long day but I would really appreciate any help.
markvanhaze
Quote from: Malcr001 on May 27, 2012, 06:12:21 PM
Yes, any channel will do. Maybe ch1 you want to keep for your aelerons, but it will work just like any other channel.
Quote from: markvanhaze on May 27, 2012, 06:18:21 PM
Unfortunately your right, you don't have enough channels I'm afraid
markvanhaze
Do I really need a channel for the OSD? If I dont connect that, will it just power on with the default OSD?
6lennn
Quote from: markvanhaze on May 27, 2012, 07:14:02 PM
its not essential so long as your happy with the default,which shows more or less everything, im pretty sure the other screens are a bit less cluttered is all
markvanhaze
I dont understand why i need 2 switches for FY31. I only need RTH from the autopilot modes available. Can I have SW1 on a 3 stage switch doing deactivate and stabilized mode and RTH on the autopilot setting?
6lennn
stupid i know but one switch has the rtl on it and the other has stability mode, and theres no way to change them around, maybe something we can hope for in a fw update?
i too only wanted, off/stability/ rtl
dont want waypoints, nor circling mode
bit of a bummer
wgt40w
MarkVanHaze
I went through exactly your same problems not long ago.
UHF Drivers - in my opinion default UHF settings are OK - EXCEPT
From memory I DID have to enter into the UHF settings to amend which channels I wanted the Pan & Tilt to be associated with. I had major problems with the Driver Software on Windows 7 which the Immersion chaps had to solve by issuing a new version which worked fine.
markvanhaze
Ok so I gave up on my tilt servo, instead Ill stick to panning using the headtracker (i only have 7 channels on my TX). While setting that up, I realised that actually ezUHF with its 8 channels wont be enough for all that I want running simultaneously anyway, so I wonder how you guys solved this?
Rudder
Aelerons
Elev
ESC
Pan
Tilt
FY31
FY31
Hornet OSD
Flaps
Thats 10 channels. I suppose I need to lose the flaps and the osd, then I can manage with 8. What did you give up on?
Also, using all 8 channels, how do I power the ezUHF rx? Currently I have a UBEC on channel 8 and if I want to use that too, where will the ezUHF draw its power from?
Loose flaps and hornet osd (
Just use a jumper in sw pins ) so that's 8
Because your using a Bec you won't / should not have red or black wire from ESC going to rx anyway so that's where you can add the BEC wires  to the throttle channel
