Fisrt Clip Posted
Started by Wowsa, June 12, 2012, 09:56:09 PM
Wowsa
This short clip is to show the image quality of a 700tvl camera I bought (buy now) on ebay for 24.99 in postage. It's from Sure Electronics and I've noticed they have now gone up to £32.00. It was not without problems eg connector blocks needed assembling and the lens housing needing screwing on very tightly for reliable operation (suspect PCB?). OSD default language was Chinese (easily corrected). I emailed Simon with the specs and he quite rightly pointed out that it would not be a commercial proposition due to the issues I'd identified. However, after messing about with the OSD and in particular opting for Anti CR in the White balance setting (whatever that means) -it turned out OK I think!! See what you think:
FPV Clip on Vimeo
Nice results from it, for the price you cant moan if your happy to fiddle a bit
Welcome to FPVUK, where do you fly? Video looked great!
Wowsa
Hi,
I'm Cheshire UK based  and have been flying from the same playing fields for years (only recently FPV).
stef1
hi wowsa i bought the 650 line camera from sure eletronics was very good until i knocked it off my plane in some bushes and could not find it
i bought one of theese 700tvl ones and i found it a pain to get the connections correct
but the camera does give a goo pic
was looking to get another one for the tri gutted when i saw the price had gone up
Tibot
Nice quality for that price!
Does this camera have nightmode?
I'm probably going to buy this camera.
Regards,
Tibot
Wowsa
Hi,
Not sure about night mode - the menus are not straightforward and there's no instructions. I felt it was worth a chance at £24.99, but they have now gone up to £32.00. It took a fair bit of fiddling to get mine working, so it's whether or not you want to take the chance I guess.
Cheers,
Wowsa
Tibot
#7
Quote from: Wowsa on June 18, 2012, 07:22:20 PM
Hi,
Cheers,
Wowsa
Okay thanks for warning me.
I'm thinking about it.
Also, do you use an OSD menu board to control the menu, or is there another way to do that?
Can you check if it has night mode if that is possible, please? That would help me very much.
EDIT: I just saw that the camera has a OSD cable shipped wth it, so no need for osd menu board.
Best regards,
Tibot
