Took a lickle shock from a lipo (via wedding ring bridging a deans connector)
Started by c0nners, July 05, 2012, 10:10:07 PM
c0nners
Learning experiance...
I run a pair of 14v lipos in my plane with a loom with 2 x Deans. What I didn't think about is when one lipo is discconected (like when packing up after a flight), one of the deans in the loom has live exposed ends.
I now have a lickle black burn in my finger the size of a pencil led and a ruff bit in my wedding ring.
I'd suggest taking your rings off if your tinkering with electrics as for an instant I must have bridged the deans + & - with my ring....
.. fecking hope I haven't fried anything.. I can't bring myself to look yet.  :'(
Conners
(p.s. My mates always said getting married was a bad idea. lol)
TBS Discovery (FPV), TBS Caipirinha (FPV), Zephyr II (FPV), Multiplex EasyStar II (FPV)
Parkzone Str
hexo
Ouch! The best way is to make sure all deans are replaced with XT60's.
Those deans have always been a pain  >:(
c0nners
Quote from: GaryB on July 05, 2012, 10:25:55 PM
They look shielded at all times. I was starting to like Deans aswell. :p
Parkzone Str
tdmodels
The only thing you would possibly be able to fry is the LiPo.  Would suggest just monitoring it a bit closer than normal on the next charge, but you should be ok.
FPV God
Flyboysee
I've had the same btw, but with charging, not on the plane - agreed XT's 60's are way better and the solder joint and heat shrink never pull away. I would suggest disconnecting the esc end first, then one at a time on batteries as a habit.
Was that painful...? Johnny understands :)
Love is a burning thing
and it makes a fiery ring
bound by wild desire
I fell in to a ring of fire...
I fell in to a burning ring of fire
I went down,down,down
and the flames went higher.
And it burns,burns,burns
the ring of fire
the ring of fire.
source: http://www.lyricsondemand.com/j/johnnycashlyrics/ringoffirelyrics.html
R
This is not a game anymore!
www.youtube.com/flyboysee
tdmodels
Quote from: Flyboysee on July 06, 2012, 01:36:11 AM
the ring of fire
the ring of fire.
Pretty apt after my curry last night   :toiletbang:
FPV God
Flyboysee
 :laugh: TD best thing for a hot Madras - put a loo roll in the ice box, should be pretty cool by the morning!
venquessa
Sure the loom should be wired with the supply always having a female connector....  It's hard to get a shock from a female connector...
Every lipo i've ever bought with deans connectors, has had the female on the battery.
tdmodels
I think what the Op was saying, is that he has two Lipos in parallel using a Y lead.  When he removes one battery from the circuit, it leaves a male deans floating whilst he disconnects the other.  I have the same issue on my Skywalker as I use 2 x 3S 4000mAh packs in parallel.
FPV God
Yes not good, its not as if you could safely pull two lipos at once so your always going to have a life exposed male end. XT60`s solve that ;)
