EzUHF questions
Started by tdmodels, April 13, 2012, 11:20:52 AM
Rudeboy
Just a note its the Uk version of the 4ch_5-8.fw i need so i can use the rx in PPM to output the 8 channels!!
My YouTube Channel
[url=http:
Rudeboy
Spoke with sander and he says UK firmware for the 4ch isn't available yet!!! he's hoping to have it out by next week!! guess I'll be using the other firmware till then ;-)
My YouTube Channel
[url=http:
Andy Sayle
Hi Folks,
I've just managed to pick up an EzUHF setup on Ebay, and I was wondering if there are any other Multiplex TX owners that have used their tx with this radio system?
Quote from: Andy Sayle on January 23, 2013, 12:46:03 PM
Hi Folks,
Small world ;)
I posted it Special Delivery about 30 minutes ago so it 'should' be with you in the morning :)
Andy Sayle
Cheers Dave, I was going to ask if you were on here!  Thanks for posting it out so quickly, if the weather plays ball, I may even get to try it out at the weekend!
Give me a shout on here if you get stuck with anything, but its ready to roll out of the box :)
Just pay extra special attention to attaching the servo/ubec leads as the pins are totall exposed and its possible to connect them around the wrong way or off by one pin (which would be very bad).
When you build your PPM lead double check everything you wouldnt want to put 12v up the PPM feed :D
Also never fire up the TX without the antenna fitted, it will slowly cook its self.
Andy Sayle
Fanstastic, thanks.
Speaking of wiring errors, I caught on on my TBS Discovery last night.  For some reason I had randomly inserted one servo plug into a header (exposed like on the EzUHF rx) the opposite way around to the other 7.  I have no idea why I missed it first time round, I guess my mind wandered!
I've just been reading the EzUHF manual off the website, and it mentions an Aux Ctrl port.  I don't suppose you know what that is, the manual is a bit sketchy in that respect!
There is a USB port for Firmware/settings/diagnostics and a port for plugging into the EzOSD so you can read RSSI etc.
