Frsky Taranis Thread
Started by Coyote, May 25, 2013, 09:02:28 PM
dp106
I've set my radio to read out the rssi values at 46 and below. Trouble is once I hear it start I instantly panic even though from what I've read I can probably go much further before having any issues (38 I believe is game over, starting shopping for a new plane).
rob.thomson
Something to consider - and I have had great success with.
Trim your model on fail-safe to cut the power and initiate a slow turn - in the direction that exposes the antenna with the lease amount of 'plane' in the way.
Normally if you loose rf, this turn and antenna exposing gives you a bit of grace time allowing you to cream back toward yourself.
MarkLloyd
Good to see the frsky L9R  long range receiver has finally surfaced....
https://www.youtube.com/watch?v=KjEbqlf1g-g
Will be interested to see the reviews.
Yeah I was interested in this LR receiver, might be what I need as second system for short range stuff. DragonLink receivers are bloody huge and not suitable for small 250s or even small wings.
I assume they are just extra sensitive? and not being transceivers for telemetry probably helps.
Pr][nCe
Anyone know if the stock on EFPV of the Taranis is the latest Rev B?
Tricopter.  FPV.
2014 Skywalker 1800.  FPV.
Emax 250 Pro. FPV.
Bixler. Night flyer. LOS.
Versa Wing.
Flyn
They have the improved sliders
