FlyingWings Venturi FPV Evo
Started by iPeel, December 05, 2014, 07:37:47 PM
iPeel
Quote from: Brucey on February 07, 2015, 05:59:48 PM
Thanks, I've got a set of smaller ones too.
I will maiden tomorrow IF Jim gets back to me in time!
What field is that? The normal one in Olney?
Yes mate, the one near my old house with the beacon.
Simon, unless it's absolutely freezing I'll be up there, charging batteries now! I'll text you when I leave but I'm hoping to be up there about 11:30ish.
I'll also have the Rocket Raven with me.
iPeel
Quote from: Cypher on February 08, 2015, 07:58:23 AM
Ok so decided to go for a different colour scheme.
Great choice!
I know you were just seeing what it looks like, but you know those elecons were the wrong way round?
iPeel
Quote from: Cypher on February 08, 2015, 03:18:59 PM
Can't decide which servos to use. Futaba S9202 (standard size) or corona ds929mg (micro).
Standard size.
iPeel
Quote from: Brucey on February 07, 2015, 05:15:31 PM
Finished! Well just the wing tips to stick on (any suggestions?) And a config for Ruby from Jim.
It's worked out 300g lighter than before. Can't wait to try it!
Just in case you couldn't quite make out the detail on the underside of Brucey's Evo, here's a close-up:
karlak
Hehehe,
Same incident , different perspective.
Awesome!
Maiden went well, just a touch to much up trim for the initial launch, but nothing a bit of power couldn't deal with ;D
iPeel
Quote from: Brucey on February 08, 2015, 04:09:07 PM
Awesome!
Yeah, a little bit of reflex on the elevons there!
http://youtu.be/HE8eOjPe2Lo
karlak
jimbo19
Very nice work on those Venturi's
Yeah standard size servos. I'm using hitec 5485hb which are digital and with the karbonite gears
Or you can check the 635hbs if you want analog.
Got the recommendation from dogzilla.
skyscraper
Looks like a good day Yesterday! Those Venturis look great.
iPeel
Quote from: Cypher on February 08, 2015, 10:47:55 PM
Is everybody using standard servos for this build?
Yep', Hitec HS645MG analogues in mine.
iwan_canobi
Think I'll order some of the digitals for mine then. Is a 60A (80A burst) ESC enough? Or do I really need an 80A? Was looking at this -
http://www.servoshop.co.uk/index.php?pid=EMAXHS60U&area=ESC
iPeel
Quote from: iwan_canobi on February 09, 2015, 09:51:56 AM
I only use analogue because they're reported to emit less RF noise.
You'd get away with a 60A ESC so long as you retro-fit a PC northbridge heatsink to it, TBH I'd still do that with an 80A ESC (and have done on mine).
This guy on eBay sells heatsinks of various sizes which I've used on ESC and VTX kit.
Neil.
