X-UAV Mini Talon
Started by BlueFlyer, June 12, 2016, 04:14:59 PM
dp106
Where was it I saw someone warning about gluing the ply frame together too tight?!  Guess what I've done :(
I checked my fit last night, I've already glued the ply frame together and stuck it to one piece of the fuse ready for when I put the two halves together.  I checked last night and when I put the halves together its not sitting flush with the back of the other half  >:(  Not sure what to do now, use loads of epoxy and hope its enough to fill the gap?!
markwilliams
Quote from: dp106 on July 05, 2016, 09:14:29 AM
I did the same.
Ended up using Gorilla glue. This filled the small gap and it worked great.
Just make sure you try the upper hatch while the glue is drying as it can be a very tight fit.
Mark.
The best crasher ever! I've had lots of practice.
MT
FX-61 Phantom
MTD
Falcon Evo
Phantom 3 Pro
jt
Mine all went together perfectly  :P   I put the fuse halves together first, got it all lined up and then added the tray(my 3d printed one). I put it on with POR and it's as solid as solid gets  :D   My hatch only got tight after tightening the wings, I had to loosen them and ease them back half a mm each.
As long as you fill the gap it will all be good and strong anyway,I think it's fairly important as it strengthens the whole thing considerably.
dp106
Quote from: markwilliams on July 05, 2016, 09:20:55 AM
I did the same.
Mark.
I did think about Gorilla glue.  My only concern with that is if it expands too much the strength of the bond is greatly reduced.
Quote from: dp106 on July 05, 2016, 11:49:09 AM
could you bridge the gap with a lollypop stick maybe? I doubt it's the end of the world
dp106
Quote from: Billy_boy_2010 on July 05, 2016, 04:27:44 PM
That's a good idea, I thought about adding some ply but at 3mm I think would have been too thick
_tj_
Motor - NTM Prop Drive 28-36 1400kv 560w - WAS one of these R.I.P lol. currently BARE.
ESC - Turnigy plush 40A
Prop - APC 8x4.5
Battery - Multistar 8000mah 4S
Servos - Turnigy TGY-50090M all round
FC/AP - MFD
FPV Camera - 700 WDR
Video - 1.2 partom relayed to 5.8
Control - Rlink UHF
FPV:-
Mini Talon & MFD
Sky Cruise 2400 - Cyclops Tornado - 700tvl
Skywalker v6 - Cyclops Tornado - 7
jt
Motor - NTM 2836 1200kv
ESC - 40A Plush
Prop - APC 10x5
Battery 8000mAh Multistar
Servos - mg90s x4
FC/AP - Vector
FPV cam - Fatshark 600tvl
Flight cam - broken lensed Mobius
Video - 1.2 Partom VTX
Control - EZUHF
Antennas Plane - UHF dipole, 1280Mhz skew
Antennas ground - 1280Mhz skew or 1.2 Circular Wireless CPatch(soon to be both on diversity)
Having still to buy anything to fit mine out - can I have any opinions on the 1200kv vs the 1400kv NTM motors.  I guess you want to spin a bigger prop on the 1200
jt
Probably not much difference from looking at Blue's time and current consumption. I can keep the current down very low 3.5A or so if flying really slowly (25-30mph), otherwise it's around 5A flying around 45mph. Mine pulls 30A or so WOT at 75mph(120kph) or there abouts(groundspeed in still conditions, not got airspeed on it). I reckon you could easily do an hour on a 8000mAh multistar if flying for efficiency  ;D
_tj_
Easy test for that jt.
Take off and put rth on.
Then watch it go round in a circle for an hour or more.
Then land lol.
FPV:-
Mini Talon & MFD
jt
 I could try and follow it with my mini sky hunter for a bit lol.
jt
 If using a pixhawk with telemetry modules, you could put a phone in the lead plane(that you control) and use the 'follow me' feature, that would be cool  :D
_tj_
Quote from: BlueFlyer on July 08, 2016, 02:42:34 PM
but I've only got one transmitter bound to both planes :(
Try flying both on the one transmitter.
That would be interesting, and make a good vid at the same time :D
FPV:-
Mini Talon & MFD
mutley2
All ready for maiden, if the wind drops later today I will nip down the field for a cheeky los maiden and a FPV after that if all goes well  :overexcited:
The last pic lol
