thUndeadMod v3.4 - openLRS S**T just got real :)
Started by thundead, February 25, 2012, 02:16:24 AM
Any Bugs So Far ?
Nope, thing is rock solid!
This hopping algorithm is rubbish!
I want More options in the config app!
I'm still using the stock FW
RSSI Is Awesome !
RSSI is rubbish!
Range is amazing!
Range is ok I guess
Range is crap
Splashy
#135
Quote from: thundead on March 27, 2012, 12:55:16 AM
Yup, found the culprit... Will move RSSI on pin 1 and re-arrange all the ports like this:
R 1 2 3 4 5 6 7 8. bed time now though lol.
Cheers webe for pointing out this nasty bug.
Mihai Out :D
Quote from: thundead on March 27, 2012, 12:36:26 AM
anyway Think I found out what;s wrong with the RSSI....  the PWM is messed up because the fw uses timer1 to drove the servos... so need to find a way round this.
Just wanted to check that you are aware that if you use PPM you have to connect pins 1 and 3 (like using a bind plug). If you are planning on putting RSSI on pin 1 then would this mess up the PPM output mode?
thundead
RSSI is now fixed. All I need is to move the Serial PPM thingy and we're good :D ETA 30 mins.
thundead
u guys want the same jumper thingy idea for the Serial PPM ? or should I make it activate via 2 pins that are close together (2 & 3) vs (2 & 4) ???
thundead
thundead
right I'll make that one clear in the readme lol
Quote from: papa_lazerous on March 27, 2012, 05:01:26 PM
Quote from: Cat695 on March 27, 2012, 04:41:19 PM
Guess what that will be my fault again......had 3.3v selected in arduino and not the 5v one
THANK YOU PAPA!!!!!
I made the same mistake,just ask Mihai..... :laugh:
thundead
papa_lazerous
Laughing at the random guest appearance at the end :) lol looks like RSSI is good again :) I'll have some range confidence this weekend now
Cat695
Quote from: thundead on March 27, 2012, 11:57:59 PM
THANK YOU PAPA!!!!!
Even after being told use 5v earlier I just kept seeing 3.3v on the board and just selected that.....so my bad but good for newbies to know
Cat695
Another question
Am I right in saying that if I set up a mix (like aileron/rudder) they don't work???
Yes they work, the mixing is done in the radio and the radio sends out each channels mixed output
Cat695
Quote from: Coyote on March 28, 2012, 01:16:11 AM
Yep they do, I had pulled a cable out when messing about with positioning.
thundead
thUndeadMod 3.5 now live
http://code.google.com/p/openlrs/downloads/list
IMPORTANT UPDATE FOR ANYONE USING MY FW.
   Changelog
   V2 Rx remapped
   Fixed RSSI bug in v2 hardware
   Added Hardware Help in configurator
papa_lazerous
I'm going flying tomorrow with working rssi :)
Me too :) Just tried it out, working great :)
