its no Mavic
Started by beesleyboy, December 18, 2016, 09:56:11 PM
Gundummy
Now if you have a spare one.... I have all the electronics waiting to be fitted to a frame like that  ;) ;)
beesleyboy
It may not work yet Gundummy.
Bit more done, here are some of the parts, I'm printing parts then changing them if necessary.
I'm glueing the carbon tubes in, so I've keyed the ends.
This is one of the front arms complete.
And this is the wires going through with the cap removed
I'm running the rear motor wires through the frame and hot glued the wires in to keep them out of the way of the battery, when it's slid in.
The wires then come out in front of the battery compartment.
I'm happy with the footprint, when the arms are folded away.
LOS not enough room. ;-)
looking really good there G. Very pro looking, which is awesome considering it's a fully DIY quad.
beesleyboy
Thanks bud, I'm spending far to much time on it, it gets put together, then striped again when I think of something else that needs changing, doing it all in Cad, is one thing,  but holding it in you're hands and looking for problems is the only way.
Badlands
More outstanding work G - love the colour scheme too.
pcnukem
Looking good bro. Make sure im with you on maiden flight.
beesleyboy
Thanks Martin.
yes Paul, I will need someone to help pick up all the bits.  :laugh:
some cad renders.
Shikra
beesleyboy
Thanks guy's.
right then, I took it up today only at a hover,  it went up really well and was nice and smooth as it came off the ground, but once it was hovering, it starts to vibrat, it still just sits in the air and easy to control, just oscillats, at first I thought it was a buckled prop or something, so I took all the props of and placed one at a time on ech motor and there all good, there is no play or movement on the quad, any ideas.
I will put up a video,  but not sure how clear it shows the problem.
Thanks G
beesleyboy
This is the video, you can see the problem at the end of the vid.
https://youtu.be/Ba6rLifO6EY
To me that looks like a slop issue with the frames leg
Speed related resonance.....because at a slightly higher prop rpm it stops...right?
   I could also be the motor that's out of balance...check the magnets are all present..?  Or run the motors up individually without their props on.
  Then, try fitting one prop at a time and hold the motor while you run the prop up...feeling for vibration......?
Badlands
I cant wait to build one of these (assuming G shares the STL's!|)
Quote from: English Turbines on January 08, 2017, 10:38:25 PM
I think you hit the nail on the head there. That's exactly what it looks like.
beesleyboy
There's no slop, and the frame is stiff as, I ran the motors without props and then with one prop at a time and there smooth as you like,  I didn't have much time today,  because it started raining,  I changed the gains and it seemed to be a bit smoother.
The props on this are 14" long, of my Inspire quad, on all the previous builds with the Naza were with 9" props,
Unfortunately I'm of to London working for a few weeks tomorrow,  so I won't get chance to look at it again until then.
I'm sure I will be able to share the files at some stage Martin, but I will need to do some work on the motor mounts,  so one could fit, standard motors, the inspire ones that are on it now have little spades on the bottom.
