FlyingWings Venturi FPV Evo
facedown
Am i bought wrong air speed sensor? It has only one tube.
Do not worry about the second hose. It is for measuring static pressure outside a pressurized cabin. As our FPV planes are not pressurized it is not needed at all.
Note though an APM airspeed sensor will not work with a MFD AP and a MFD AP airspeed sensor will not work on an APM because their PCB are different.
facedown
Quote from: Coyote on October 24, 2015, 02:50:10 PM
Thanks. In mfd home page sensor kas 4 wires but from fpvmodel.com has only 3 wires. Why need for 4 wires?  Usaly use 4 wires to communicate both ways. But airspeed sensor just communicate one way? Thanks. Apm is analog but mfd digital? Somethink like that ?
facedown
Please help. I instal mfd to venturi and servo response to radio to different side. And roll for stable mode has to be reversed as well. How.?
#575
In stabilise mode when you roll the plane left side down the left elevon should go down and right elevon should go up. When you point the nose down both elevons should go up. If one of those is true but not the other then you have the servos plugged in the wrong way round. if both are not true then servos need reversing in the AP setup screen.
Once you have the plane responding in stabilise mode go to manual and reverse your TX servo outputs so manual mode moves the servos correctly.
facedown
Thanks. . Now i need to calibrate and done. I prelode x6 from plane list. Is it write or use other ?
Yes, that's as good a place as any to start, then you can get the gains tuned in flight if you have a pot or slider set on channels 7 and 8.
Quote from: facedown on October 29, 2015, 10:22:32 PM
You could use X6 I guess, it is a similarly sized elevon type aircraft, but personally I wouldn't use a pre-set. I would start with a clean model. Go to plane settings --> plane type, and select WING
facedown
how you hold your yi camera secured to airplane?
Quote from: facedown on October 31, 2015, 05:23:15 PM
I lost one from my falcon after doing inverted stuff as it was just shoved into the foam.
I now have a velcro strap holding it in.
dp106
Yep same here, I've got mine in the pretty tight but a Velcro strap as backup
facedown
can you send picture how it looks.
facedown
facedown
