FlyingWings Venturi FPV Evo
Started by iPeel, December 05, 2014, 07:37:47 PM
skyscraper
Quote from: iPeel on June 22, 2015, 10:32:45 PM
It'll bend, it's just a matter of making sure the right bit bends! The thing will want to bend on the bottom of the mount if you're not careful.
I've made a 2 degree block using the table saw and I just hammer the mount against it to get it at the right angle and flat. Another option is to mount the base in the vice and prise the motor mount with a large screwdriver.
Seems like a lot o work.. and none too precise
How about shim washers  TBH normal washers will be OK unless you are picky!
http://www.accuscrews.co.uk/shim-washers/62835-HSHN-3-6-0-1-A2.html?uk_google_shopping=1&gclid=CKvVq5Wvq8YCFfQZtAodmfYAoA
dp106
Quote from: skyscraper on June 25, 2015, 07:30:30 PM
I've got two 'regular' washers under the back so far. Was testing it out then my other troubles started :(
nowler
i've got to say from my own experience of 3 evo builds, if it's balance correctly about cog, the thrust angle is pretty good imho.
250 argonauts, raven night flying wing, z3, skywalker x8, bixler 2, venturi evo fpv, venturi sport, trex 600e pro dfc, tbs disco, trex 500L dominator
gr4ndp4
Greetings from sunny Northumberland, I have just taken delivery of a Venturi FPV EVO after taking in much of everyone's thoughts, comments and experiences building and flying this wing. I have a couple of questions but first would like to draw attention to the following build video that as a newbie with laminated foam wings I found very informative. I'm happy to echo the thought that a similar video on youtube for Flying wings products would be welcome.
https://www.youtube.com/watch?v=KdVRE4XanZ8
What paint is thought to be best for the ply centre section and elevons? – am I correct in assuming acrylic car spray paint works well?
Has anyone modified the front plate to take a Gopro camera in its case? Any experience and a photo would be good.
Tread where the Roman Legions trod.
iwan_canobi
There should have been an option at checkout to have the Gopro mount instead? There is a dedicated center section that is designed to fit the gopro properly, what one do you have?
gr4ndp4
I have the Gopro3 option, looks like it'll only take a "naked" camera.
iPeel
#441
Quote from: gr4ndp4 on July 01, 2015, 12:43:04 PM
Yes as far as the kit is concerned, although Brucey cleared that whole bay away and fitted his GoPro in the waterproof case with a board cam alongside. Structurally there's nothing stopping you doing that, although I think he butchered the GoPro case in order to fit it.
Edit: WRT your previous post, acrylic paint is the one you need, that won't harm the foam at all.
gr4ndp4
Many thanks for the advice. I'll try & post a build report in due course.
Yeah I have a gp3 in and knock off gp3+  case from goodluckbuy. To make it fit I chopped the lugs off the bottom and the button on the side for the wifi.
karlak
@Brucey, do you have a link for that FPV camera please ?
ThunderstruK
Hi, could anyone with one of these tell me what the internal width of the component bay is? I've had a look, but can't find any mention of it.
Thanks in advance!
gr4ndp4
Looks good, I have a 3 case (from an expired 3) into which the 3+ fits, hacksaw in hand.
iPeel
Quote from: karlak on July 01, 2015, 06:47:49 PM
Is there anything you're not going to replace before the maiden Simon?
gr4ndp4
Quote from: ThunderstruK on July 01, 2015, 07:49:38 PM
Thanks in advance!
about 11.5 cm wide by 4.5 cm fore & aft.
