Bixler FPV Build
Started by Pr][nCe, August 01, 2012, 09:06:18 PM
Pr][nCe
#45
Quote from: Big_Red on November 04, 2012, 11:46:58 PM
Fantastic thread, enjoyed following your progress. Like you before this build, I'm now doing the rounds putting together some idea for my own first FPV build. What sort of results are you getting with Range/Signal quality? How much do you think it's cost you? (I'm about to pull the trigger on my Bixler order).
Looking forward to seeing more videos.
J.
Hi J
As for how far i went on the vids i am unsure "edit google earthed it and it said 550m" but i had no issues at all with signal until i put it in a hard bank after i went a wee bit past the Van, i had 1 beep from my TX "turnigy 9x std, with frSky module" and that was it that goes for the Vtx also i had a little fussiness same place but nothing other than that was rock solid.
Thats a good Q: how much hhhmmm, will have a look into it for ya J.
Cost "checks over sholder mrs not looking"
break down so far.
Bixler EPO 1400mm - (ARF)   30.89   1   30.89
TURNIGY Plush 40amp Speed Controller   12.39   1   12.39
2212-06 28A 2200KV SP Brushless Outrunner Motor   8.89   1   8.89
EMM28TS GWS BRUSHLESS MOTOR MOUNTs x2   2.49   1   2.49
APC 6x4E Prop   2.35   1   2.35
Control Horns 16x20mm (10pcs)   0.60   1   0.60
Turnigy TG9e 9g / 1.5kg / 0.10sec Eco Micro Servo   1.23   2   2.46
HXT900 9g / 1.6kg / .12sec Micro Servo   1.67   2   3.34
Turnigy 4mm Heat Shrink Tube - BLACK (1mtr)   0.16   1   0.16
TURNIGY BESC Programming Card   4.31   1   4.31
Turnigy Pure-Silicone Wire 16AWG (1mtr) Black   0.80   1   0.80
Turnigy Pure-Silicone Wire 16AWG (1mtr) Red   0.80   1   0.80
PolyMax 3.5mm Gold Connectors 10 PAIRS (20PC)   0.93   1   0.93
Nylon XT60 Connectors Male/Female (5 pairs) GENUINE   1.98   1   1.98
Servo Extension Lead 420mm (5pcs/bag)   1.56   1   1.56
Flat 26AWG servo wire 1mtr (R/B/W)   0.24   1   0.24
TURNIGY 8-15A UBEC for Lipoly   8.87   1   8.87
HK-171 Thread Locker & Sealant Medium Strength (Blue)   2.51   1   2.51
Linkage Stopper M3x2xL11.2mm (10pcs/set)   0.84   1   0.84
CF Rod 3mm bottom fuse and under fuse tail servos   2.55   2   5.10
CF Rod 5mm insert into wing spar   5.59   1   5.59
CF Tubing 3 x 1.5mm horizontal and vertical stabilizers   3.35   2   6.70
Gator Glue   7.00   1   7.00
CA Glue   3.00   1   3.00
Extreme Packing Tape   6.00   1   6.00
3M plastic wing hooks   4.95   1   4.95
Rubber Wing Bands   3.50   1   3.50
            128.25
Pan & Tilt   25.00   1   25.00
Metal Gear Set HS81MG "for Tilt servo"   13.49   1   13.49
Hitec HS-81 Micro Servo 2.6kg/16g/0.11sec   8.05   2   16.10
DIY Bixler FPV Camera Mount    2.47   1   2.47
Soft Ferrite Rings 16x7x10 (5pc)   0.67   1   0.67
Capacitors for LC Filter   1.20   1   1.20
Super Simple Mini OSD    4.93   1   4.93
Hook Up Wire Set   0.61   1   0.61
ImmersionRC 5.8Ghz Audio/Video Transmitter - FatShark compatible   43.39   1   43.39
5.8 GHz Bluebeam Whip Antenna Set (RHCP)   40.69   1   40.69
HobbyKing 4-6min Epoxy Glue   0.55   1   0.55
3s Balance plug pigtails    0.80   1   0.80
Sheet of lite ply board   5.50   1   5.50
M3 Tee Nuts   2.00   2   4.00
M3 x 30mm plastic bolts   1.25   2   2.50
5x Mini Female JST connector 12cm long silicon wire   1.25   1   1.25
5x Mini Male JST connector 12cm long silicon wire   1.25   1   1.25
Airwave 5.8GHz A/V Receiver   31.29   1   31.29
Cables/Connectors   5.00   1   5.00
            200.69
Turnigy 9X 9Ch Transmitter w/ Module & 8ch Receiver (Mode 2) (v2 Firmware)   33.45   1   33.45
Turnigy 2650mAh 3S 1C LLF Tx Pack (Futaba/JR)   7.93   1   7.93
FrSky DF 2.4Ghz Combo Pack for JR w/ Module & RX   31.27   1   31.27
Turnigy 9X LCD Backlight Kit - Blue (DIY)   3.09   1   3.09
FrSky USB Cable   5.26   1   5.26
TurboThumbs Super Big Futaba Rocker (Blue)   3.07   1   3.07
TURNIGY Transmitter Strap   0.61   1   0.61
            84.68
Turnigy Accucel-6 50W 6A Balancer/Charger   24.79   1   24.79
Power Supply Adapter 12V 5A for iMAX B6 B5 LCD MONITORS (280531661708)   6.49   1   6.49
Charging harness   1.67   1   1.67
            32.95
Fat Shark Dominator 3rd Generation modular FPV System   185.97   1   185.97
Fatshark Battery for Dominator Goggles   25.05   1   25.05
Fat Shark Dominator Optional Head Tracker Module   42.13   1   42.13
Fat Shark Dominator 5.8ghz Module.   19.22   1   19.22
Fatshark FPV PS2/3.5mm JR HT Connection Cable (1 meter)    1.69   1   1.69
600TVL SONY SUPER HAD CCD D-WDR Color Board Camera with OSD Menu DNR   28.07   1   28.07
SMA male plug to SMA female jack right angle adapter   2.79   2   5.58
30CM JR Servo Extension Lead 5pcs   1.28   1   1.28
15CM JR Servo Extension Lead 5pcs   0.94   1   0.94
FPVUK Membership   15.80   1   15.80
            325.73
Flight Case    20.00   1   20.00
Cello C16100F 15.6" LED TV DVD Freeview USB PVR - 12V   109.99   1   109.99
Archos 404 DVR and docking station   210.00   1   210.00
Digital Voltmeter, 12V D.C. Battery Monitor Panel Meter (320701838199)   9.65   1   9.65
Yuasa NP7-12, 12V 7Ah    19.45   1   19.45
12v Power Switch    4.00   1   4.00
MDF   12.00   1   12.00
hinges 2 pack   3.75   1   3.75
Case foam   13.20   1   13.20
Machine Screws/Self-Tapping W/Shoulder 2.3x12 (bag of 100pc)   0.91   1   0.91
            407.95
Paint   3.50   2   7.00
Turnigy 2200mAh 3S 25C Lipo Pack   5.57   5   27.85
On Board Lipoly Low Voltage Alarm (2s~4s)   1.13   1   1.13
masking tape various widths   6.00   1   6.00
glue gun   8.00   1   8.00
GoProHD Camera Cable (ImmersionRC Compatible Audio and Video)   8.14   1   8.14
            58.12
            1238.37 + some major P+P charges
and more i forgot lol
Tricopter.  FPV.
2014 Skywalker 1800.  FPV.
Emax 250 Pro. FPV.
Bixler. Night flyer. LOS.
Versa Wing.
Big_Red
WOW!!
Thanks for that, I've copied your list to use as reference. How do you feel about that total amount? more then you thought? I guess it's like everything else.. I'm sure you'd have bought that in stages to arrive at where you are now with your setup. Most of it is transferable to future aircraft too huh?
I've ordered a Bixler but it's on back order from the HK UK warehouse.
Whats next for you? plans to improve on any of it?
J.
Pr][nCe
Total amount is understandable as i started from scratch i had nothing, so had to buy everything, but yes its just a progression over a while and been used now on many more planes, tricopters and still got spares if needed. as for upgrade the bixler is sorted only thing im after is a nice OSD, looking at Cyclops Storm v1.2 with RTL. its just a case of buying the stuff you need now, so you dont need to change it out for something else later on like the ubec get a nice 1 in there first as last and your sorted to upgrade rite up to full FPV with P&T.
Tricopter.  FPV.
Emax 250 Pro. FPV.
Versa Wing.
That`s one comprehensive list ! Kinda puts it in perspective when its laid out just how much we invest
Pr][nCe
Yes just went and cast my eyes over what receipts i could find. no doubt their was more that had to be hidden like this thread from the mrs lol
but it does add up
Tricopter.  FPV.
Emax 250 Pro. FPV.
Versa Wing.
I just joined your Bixler club mate, but got the 2
Pr][nCe
very nice hope to get out and about with um soon mukka.
Tricopter.  FPV.
Emax 250 Pro. FPV.
Versa Wing.
c0nners
Good job Prince. Enjoyed the thread.. Might get my Easystar out the loft. :)
Anyone know how much bigger a Bixler is to an EZ*2?
TBS Discovery (FPV), TBS Caipirinha (FPV), Zephyr II (FPV), Multiplex EasyStar II (FPV)
Parkzone Str
keukpa
Nice thread indeed!  I'll be using this as reference to building my Bixler 2.
I've currently got the Bixler 1 up and running but I threw it together! Still flys nice!
Looking at your shopping list, WOW! I was in the same boat a few months ago, had nothing, on hobby king alone I've spent about £1k
Still, keeps me off the streets ;)
Keukpa
Pr][nCe
Cheers lads, yes it all adds up as with any hobby but you got to start somewhere.
just need the damn weather back now :)
Tricopter.  FPV.
Emax 250 Pro. FPV.
Versa Wing.
cortex
Quote from: Pr][nCe on August 05, 2012, 09:45:59 PM
Cheers Simon.
got an hour or so spare today so knocked this up,
added a few more CF rods to the Fuse.
Did you need to add much weight to the tail to balance the COG with the Gopro onboard?
Pr][nCe
by moving the Radio Rx and the LC Filter to the rear, my CG was very good with all the fpv gear in the pod, i had to move my battery back about 15mm. Sorted.
you only need a little weight when its that far back on the tail.
Tricopter.  FPV.
Emax 250 Pro. FPV.
Versa Wing.
lrosm
What a fantastic thread!
exactly what i need.  i am at the beginning of my Bixler 2 FPV build.
just building up my shopping list too.  though I dont think i will get as much cool gear as you.
My main issue is strengthening the plane, changing the horns, clieves, carbon fibre etc etc.
Pr][nCe
Nice to see more Bixlers in the sky  :D
Tricopter.  FPV.
Emax 250 Pro. FPV.
Versa Wing.
Blimey Darren where you been mate ??
