Frsky Taranis Thread
Started by Coyote, May 25, 2013, 09:02:28 PM
Flyn
I've got a Zippy 2500mah 3s in mine, it fits & works a treat.
Here the uk store link http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=32116
Flyn
#226
Also if you do the speaker mod, you might find the larger speaker is susceptible to picking up rf noise from your 2.4 & UHF antennas in the form of a slight buzz or hum.
I found using some copper tape (slug barrier tape) from my local garden centre does a pretty good job of curing it. All you need do is cover the internal portions of the two case halves around the speaker with the copper tape making sure you won't cause any shorts, I added some foam as well just to deaden the space to improve the sound of the new speaker & to stop any bits of tape that might work loose from dropping onto live circuit boards etc
Loving the new speaker thou it's much better
keukpa
I still need to design the speaker adapter! :)
pk-surfing
I designed this one to do the 40mm speaker mod on my Taranis.
I've attached the file if it's any use to anyone.
PK
Zeeflyboy
Oh crap, I was supposed to send you the STL wasn't I keukpa... I'll do it in a mo
Edit - or use that one ^
keukpa
Quote from: pk-surfing on December 27, 2013, 12:33:13 PM
PK
LOL PK, I just opened that. According to my Printer, it's 2 meters in Diameter!!! How HUGE is your speaker?! heheheh
pk-surfing
OOps. don't know why that is, I'm opening it in MakerWare and it opens up at the right size to print but I must have some odd units maybe ?
Maybe best to wait for Zeeflyboy posting his file.
PK   :)
Matt101
Quote from: keukpa on December 27, 2013, 01:06:27 PM
PK
Bet the sound quality is AMAZING!! :D
keukpa
Quote from: Zeeflyboy on December 27, 2013, 12:33:35 PM
Thanks Flyboy! :)
BTW, what 3D printer do you have? I just say your micro quad...impressive print.
Keukpa
Zeeflyboy
Makergear M2 with E3D all metal hot end.
I think it can do better, the boom/motor mounts are quite complex so needs some trial and error to get the best out of it. Will try at 0.1mm when I get back with some different settings.
Sevensixty
Hi guys,
Would it be possible to post the stl file for this if it is not copyrighted?
thanks in advance
Phil
Jake Bullit
Can I charge my stock battery with this?
rob.thomson
Yes.
Any 12v source.
The circuit in the taranis will even auto swap polarity!
Jake Bullit
Great, thanks Rob, just wanted the treasure reassurance of a second opinion.
rob.thomson
For those annoyed with a buzzy taranis.
This fix.
http://www.thelasercutter.com/2014/01/taranis-speaker-hum-one-many-solutions/
Really works!
I just used two ferrite TDK clamps yo test.
Instant noise reduction :)
